Staining my Deck
Hello everyone,
I am about to re-stain my deck. The previous owner had used regular paint on the deck. I know that I have to strip the paint, clean it and stain it.... But what brand do you guys recommend for each step. (There are so many in the market) Thank you.... |
Personally i use Porter clear stain and deck, you can also get the semi tranparent or even go to a solid colour if thats the effect you want. I prefer to see the wood grain so use the clear, but thats up to you what you want . GL :)
If it's painted, be prepare to sand it to death. You can try a full strength paint stripper like "Dad's" that can be found at your local hardware store...be extremely cautious with chemical strippers though. I am hesitant to recommend professional grade products we would use, but you can try a sodium hydroxide stripper which would probably take several applications at your own risk. You'll then need to nuetralize the stripper on the wood before applying a stain using either oxacilic acid or citric acid. Then, you would need to allow it to dry (check with a moisture meter for less than 12%) and apply your new stain...assuming all of the paint comes off cleanly. Be prepared to use a solid color stain to get a good look.
For a good solid color stain I would recommend cabbots, semi-transparent I would recommend Ready Seal. Good luck with your project...there are many variables in what you want to do. I hope some advice will be helpful. |
I'd try some of the ones you can get at your local paint shop
To be honest, it's labor and chemical intensive, and usually not cost-effective for someone to hire me to do it The wood (decking) really has to be in good shape other-wise for it to be worth it, and that's rarely the case when it comes to someone calling me for paint stripping a deck You local paint shop will have a good idea of what's (relatively) effective and legal for your area chemically, and you'll still have plenty of sanding to do after stripping and before staining |
| All times are GMT -4. The time now is 01:56 AM. |
