Staining Mantle Question - Painting - DIY Chatroom Home Improvement Forum
Old 12-10-2013, 04:23 PM   #1
Staining mantle question
I recently bought a mantle from pearl mantels and will be staining it tonight. I've lightly sanded it with 220 sandpaper but had some questions about the wood putty/glue that is at the joints.
Do I completely sand out the wood putty and glue? Or should I just leave it as it is (sanded lightly) and stain over it?
faromic is offline   Reply With Quote
Old 12-10-2013, 04:31 PM   #2
Rewards Points: 13,750
Not sure how were going to know with out seeing it.
If this was a quality product you should not be seeing any glue or filler.
Any fillers or glue will not look the same as the wood when stained.
Old 12-10-2013, 04:34 PM   #3
I've attached some pics
Old 12-10-2013, 04:36 PM   #4
Pictures do not come up.
Old 12-10-2013, 04:37 PM   #5
How do I attach pictures w/o a url?
Old 12-10-2013, 04:44 PM   #6
I figured it out...see below
Staining mantle question-2013-12-09-19.28.54-1-.jpg   Staining mantle question-2013-12-09-19.29.00.jpg   Staining mantle question-2013-12-09-19.28.48.jpg   Staining mantle question-2013-12-09-19.29.15.jpg
Old 12-10-2013, 06:36 PM   #7
Jmayspaint's Avatar
Rewards Points: 534
That's a lot of filler...
It's a nice mantle, but from the pics it kinda looks like somebody made a mess with the filler. It's odd to see it in the joints like that.
It looks like filler is stuck in the grain in several areas.
Sanding will help. Always sand I the direction of the wood grain when hand sanding. If you have an orbital for the flat parts that would help too.
Jmayspaint is offline   Reply With Quote
Old 12-10-2013, 06:40 PM   #8
Jmayspaint's Avatar
Rewards Points: 534
You want to at least sand out all the filler that has penetrated into the wood grain around the filled areas.
Old 12-11-2013, 12:08 PM   #9
Ok I will do that..should I also lightly scrape out the filler at the joints?
Wood staining questions wengang1 Painting 2 09-17-2012 09:49 AM
Venting over the range convection oven question johncle6023 HVAC 4 08-31-2012 08:30 PM
Deck Staining Question Punjabtantrum Painting 8 06-23-2009 10:51 PM
Deck Staining question boddington Painting 3 05-04-2009 02:37 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
