Staining Know How Assistance - Painting - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 12:49 PM   #1
Rewards Points: 666
I am in the process of sanding a shelf(that has not ever been stained) and applying polyurethane. After sanding and then staining the wood, I applied a coat of polyurethane over the stain. Upon the polyurethane drying, the surface of the wood became very rough. What is causing the roughness? I am assuming that it is the polyurethane that has caused this. Am I supposed to lightly sand the surface after applying the polyurethane and reapply another coat or use something else over the stain? Thanks!
kennykenny is offline   Reply With Quote
Old 12-13-2010, 04:51 PM   #2
Rewards Points: 526
You have 'raised the grain'. When completely dry lightly sand the surface using a very fine grit paper, 320 or so, and then apply another clear coat.
Windows is offline   Reply With Quote
Old 12-14-2010, 12:07 AM   #3
Faron79's Avatar
Rewards Points: 260
4 questions:
1) What species of wood are you doing?
2) Oil-based stain or Water-based?
3) Oil or Water-based Poly?
4) What brands of Stain & Poly?
For shelves, I'd do 4 coats of Poly. 2 coats is only a BARE MINIMUM...IMO.
2 Coats only STARTS to look even.
If Oil Poly...usually have to wait 8-12 hours for each coat to be decently sandable. Depends on the brand and your home/shops' environment.
Faron
Faron79 is offline   Reply With Quote
Advice needed on staining wood fence deerhunter Painting 0 10-29-2010 11:27 PM
staining cabinets need pro pointers Chemist1961 Carpentry 6 10-11-2010 02:20 PM
Deck staining nightmare sk8z Painting 14 12-29-2009 06:24 PM
Staining concrete flooring - questions on cleanup and relief cuts vseven Flooring 3 12-15-2009 09:07 AM
