Old 10-12-2010, 05:44 PM   #1
Staining distressed heartwood pine floor
I installed new heartwood pine floor. Will stain with minwax gel stain. Have already beaten the hell out of it with chains, nuts, etc. for a distressed look.
Questions: minwax gel stain label says first treat the pine with minwax wood conditioner (a sealant for softwood) I'm considering it, but the product instructions say to follow the application by rubbing with steel wool.... Rubbing a whole floor with steel wool doesn't sound fun. Is this even meant as an application for flooring or just for small items like furniture?
Can I get by without the sealer? Just stain bare pine, which is planed very smooth? Given that the floor is supposed to look distressed, what are your suggestions for finishing it?
Thanks in advance!
tom_matthews is offline   Reply With Quote
Old 10-15-2010, 07:17 AM   #2
Use a conditioner, pine is porous and needs to have the pours filled so to speak, this way your stain will go on evenly and not splotchy. Wipe on, Wipe off. Then stain, is as easily as I can post it. Good Luck............
mark942 is offline   Reply With Quote
Old 10-17-2010, 01:16 AM   #3
old masters gel stain is a much better product.
hammerheart14 is offline   Reply With Quote
Old 10-17-2010, 01:53 AM   #4
the fact you used pine on the floor will get distressed soon enough of its own. that's a soft wood. do agree with the style though. trying to make a clean looking pine floor would be insane to try and keep perfect.
racebum is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Staining concrete patio floor vheiser Flooring 0 06-02-2010 07:03 PM
installing a pine floor and not sure if my subflooring is OSB or particle/press board brenda o Flooring 4 09-28-2009 12:44 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Staining hardwood floor noodlesalad Flooring 4 05-29-2006 09:13 AM
