Staining A Deck White - Painting - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 03:32 AM   #1
C&R
C&RImprovements's Avatar
Question
Staining a deck white
I have two decks on my home. I would like to stain then white . One has never been painted nor stain so its no problem, but then old deck has grey pourch paint on it.
Question is do I need to strip then grey off or will then stain cover? If I need to strip whats then best stripper to use?
C&RImprovements is offline   Reply With Quote
Old 08-15-2011, 08:40 AM   #2
I have used an exterior stripper made by Behr for porch/deck finishes several times. It takes a little more than the label states when removing a painted surface vs a stained one. I found that removing the residue with a pressure washer shaved hours off the project and had me staining the next day.
One word of caution: be very careful walking on any surface that has this stuff on it - it's slippery.
HDPaintPro is offline   Reply With Quote
Old 08-15-2011, 08:59 AM   #3
C, if you're using a solid stain there's no need to strip. Just give a good cleaning and sanding and go. If you're planning to use a translucent stain, think about using a solid stain.
Old 08-15-2011, 09:08 AM   #4
Sorry to jump back in...but, you need to make sure that the "grey" paint is NOT an oil based porch/floor paint. Nothing will stick to this but another similar product.
I would still go with the stripping.
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Deck staining nightmare sk8z Painting 14 12-29-2009 05:24 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
solid staining a deck ruthi Painting 4 06-11-2008 08:21 PM
