Staining A Deck And Sanding - Painting - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 10:34 PM   #1
staining a deck and sanding
Hi everyone!
I'm getting ready to prep to stain my deck tommorow.
It was stained about 6 years ago and really needs new stain!!
I'm gonna be using Cabot semi-transparent.
Anyways, My question is, if I am planning on sanding the deck, should I power wash it (with a wood stripper followed by a rinse), let dry and then sand...
or should I sand then power wash (with wood stripper followed by a rinse)??
I was planning on renting a random-orbit sander... good choice?
Also, how long should I wait between the power washin and sanding (or vice versa)? Does the deck have to be completely dry before I sand? Can i begin stainign right after sanding?
Sorry, it's alot of question to answer but I would REALLY appreciate your knowledge! Thanks a bunch!
erinherbst is offline   Reply With Quote
Old 07-02-2011, 10:48 PM   #2
power washing will raise the gain of the wood.. you should give it a good day in the sun to dry then sand.. then tack cloth the dust off.. then apply your stain.. but if you dont keep the dirt off youll be staining the dirt into the wood.. good luck!
jarheadoo7 is offline   Reply With Quote
Tags
cabot , sander , sanding , stain
Splinters/ Sanding a wood deck adam3477 Carpentry 6 06-20-2011 04:27 PM
How thorough the sanding on deck? Hossenfeffer Painting 2 06-17-2011 07:47 PM
Need your advice on staining a deck Mikeydidit Painting 7 06-07-2011 05:52 PM
Sanding rough PT deck boards houseinthewoods Painting 2 06-24-2010 07:27 AM
Painting or staining a deck slug Painting 1 07-27-2008 02:30 AM
