Staining Deck With ??? - Painting - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 06:14 PM   #1
Rewards Points: 874
Staining deck with ???
I am getting ready to stain my fairly large deck this weekend. What is the best method to apply the stain to the decking and the spindles? I have heard mixed opinions about using a roller. I used a lambs wood type of pad on my desk when I stained it and it went in great. Thanks
Mstrlucky74 is offline   Reply With Quote
Old 06-06-2013, 07:31 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
If it's a stain, I like a pad applicator.
MTN REMODEL LLC is offline   Reply With Quote
Old 06-12-2013, 04:40 PM   #3
Rewards Points: 264
I agree the deck pads work very well for this. I don't think their is a better option.
Awoodfloorguy is offline   Reply With Quote
Old 06-13-2013, 05:32 AM   #4
Rewards Points: 874
Use the pad for the spindles as well? Thanks
Old 06-13-2013, 09:21 PM   #5
Painting Contractor CT
Rewards Points: 77
Post
Pads are great, using a roller works well as too.
Good Luck!
KD PAINTING is offline   Reply With Quote
Old 06-20-2013, 09:39 PM   #6
Rewards Points: 874
Any advice on what technique to use when applying the stain with the pad? Long strokes, overlap etc.? Staining tomorrow. Thanks
Old 06-20-2013, 10:18 PM   #7
Gymschu's Avatar
Rewards Points: 460
Actually, a roller works quite well. The key is to BACKBRUSH your work. With a pad you have to be careful of snagging it on splintered wood. With a roller, you don't have that problem. A standard 9" roller sleeve with a 1/2 inch nap works fine. A whizz 4-inch roller works well on spindles. Those things hold lots of paint and do a nice job of getting all 4 sides of a spindle. Not knocking the pad, that's a great option, but a roller works well too.
Old 06-20-2013, 11:56 PM   #8
Rewards Points: 4,792
Consider that there are 3 basic things you need to accomplish whenever you paint or stain (depending on what you're doing, you can accomplish 2 or even all 3 in one motion).
1) get paint/stain from container to your surface
2) work the paint/stain into the surface
3) give it a good surface finish
For example, you could use a roller to do 1), and then brush back over it to accomplish 2) and 3).
Or you could use a pad or brush to do 1) and 2), and then use a longer stroke with the pad or brush to smooth it out (3).
Or a super fast method would be for 1 person to spray on the stain (1), and a second person use a brush or pad to do 2) and 3). (This is in fact how some pros paint houses.)
By the way, I think a stain mitt is the best way to apply stain to spindles/ballusters.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Gymschu (06-21-2013)
Old 06-21-2013, 12:10 PM   #9
Gymschu's Avatar
Rewards Points: 460
www.deckstainhelp.com
Old 06-22-2013, 10:14 PM   #10
cdaniels's Avatar
^^^^^what he said.Rollers and backbrushing the decking boards.I don't backbrush the spindles though the 4 inch does fine on it's own.Uswually can get pretty much every bit of them with the Whiz.I have no experience with a pad so I don't know.I tend to stick with what works for me.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 06-22-2013, 10:42 PM   #11
Jmayspaint's Avatar
Rewards Points: 534
It will depend also on the type of stain you are using.
With any thicker bodied stains, like solid or semi solid, a roller is the way to go. I like mini rollers for pickets.
Thinner stains like semi-transparently or toners, don't roll so well because they are so thin. That's why pads are used, or you just brush it.
If you said what type, I missed it.
Jmayspaint is online now   Reply With Quote
Deck Staining GanJa Painting 20 02-11-2014 02:47 AM
Best prep and material for staining deck posts? apaintedgal Painting 3 11-18-2013 07:03 AM
Staining a new fence and an old deck kkamprowski Painting 6 03-16-2012 11:38 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Deck staining nightmare sk8z Painting 14 12-29-2009 06:24 PM
