Staining Around Chain Line Wires. - Painting - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 01:31 PM   #1
Rewards Points: 2,210
Staining around chain line wires.
Thinking about doing a white chain link on wood posts and wood rails fence.
This gives an open view without looking institutional.
When using treated wood they say to wait 1 year before staining.
So if I build the fence then try to stain it I got to work around the chain link on the rails and posts. Fence has to go up right away.
So do I stain and wipe it off the chain link, use a tiny artist brush near the chain link and try to get very little on it?
any thoughts?
Thanks for any advice.
mae-ling is offline   Reply With Quote
Old 07-12-2012, 02:35 PM   #2
Rewards Points: 13,300
Chain link with wooden post? I've never seen that before, Why not steel post.
If you want the fence to be less visable then just use black coating fencing. It tricks the eye and it becomes less visable. White will stick out far more.
Old 07-12-2012, 03:09 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
How does the link attach to the post?
In how many places?
Might be possible to run tape with masking paper down both sides, but would have to actually see what we're talking about to know.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-12-2012, 04:27 PM   #4
(the original)
Rewards Points: 756
Sounds like you plan to overlap the fencing across the posts. Don't. Install it in sections between the posts with tension bars offset a little from the posts. You might have to modify some brackets to hold the bars, but it would eliminate the staining issue and look a lot better.
ratherbefishin' is offline   Reply With Quote
The Following User Says Thank You to ratherbefishin' For This Useful Post:
oh'mike (07-12-2012)
Old 07-12-2012, 06:00 PM   #5
Mr. Paint's Avatar
If you do what ratherbefishin' advises and use a turnbuckle system of attachment, then all you have to do is remove each section to maintain your posts and rails.
Mr. Paint is offline   Reply With Quote
Old 07-12-2012, 09:34 PM   #6
The reason for no metal posts is they and the rails look institutional.
I like the idea of between the posts just not sure of how that would attach.
ON the post it would attach with large staples. Yes when close you will see it but not much.
Old 07-12-2012, 10:29 PM   #7
Here is an image of one, mine would be slightly different but same idea.
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 10:27 AM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 03:29 PM
Need some guidance on recessed cans wiring..... TyWebb Electrical 6 02-17-2010 02:01 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
