-   -   Stained some wood, should I put on clear coat? (http://www.diychatroom.com/f4/stained-some-wood-should-i-put-clear-coat-144315/)
god 05-20-2012 09:07 AM
Hey guys
I have been refurbishing an old slot machine from the 1930's. The case has both metal and wood finishing. It has been repainted several times before I got it so I was not dealing with orignal paint or anything. I used varathane premium wood stain, (early american ) and didn t know if mabye I should use clear coat to protect the finish?
Over the years I have used stain a few times for house hold projects and I always have put on several coats of clear coat to protect the finish. But of course, these were shevles where items were going on the wood so I thought it really needed protection. I was leaning on not putting any clear coat to protect the finish on the slot machine.
What would you guys do?
Brushjockey 05-20-2012 09:23 AM
Stain is not meant to be the finish- just the color. It has no protective qualities.
Lots of good choices in finishes- think about sheen level- Satin is the most used, but it could be either flatter to retain the raw look, or shiner.
Varathane makes a good oil poly, if you want to go waterborne I know of no better to use than Zar Ultra Max- tough enough for floors. Ace Hdwe, among others carries it.
ratherbefishing 05-20-2012 10:51 AM
I've had really good luck with Minwax and Behr Tung Oil Finish. Easy to apply and just the right amount of sheen for me.
god 05-20-2012 03:25 PM
I guess by sheen you mean whether its shinny finish or not. I like the raw look of it now, I ll check out a satin finish as thats not too shinney.
I used a oil base for the stain so I guess I have to go with oil for the finish?
Brushjockey 05-20-2012 04:01 PM
No- you can use either oil or waterborne as long as the stain is dry.
The flattest ( raw) look might be Dead Flat varnish by modern masters.
