Old 02-10-2013, 08:32 PM   #16
Rubbin walls since'79
Brushjockey's Avatar
Stain washes right off railing
Hey ric ( sorry- gonna hijack this bit..)-
i have a job next week that I am darkening existing handrails and knewls to match a new dark floor.
Oak with I believe conventional poly on them.
Couple of Q's -
You say clean with den. alcohol- I thought spirits did a better job of cutting waxes and polishes... comments?
My plan was also to clean after that with Krud Kutter ( oh- and scuff sand) - then tone WB Zar ultra Max with Transtints and build up the color- finishing with a clear of Ultra max.
Was hoping that a transition coat of Uni Shellac was not needed for adhesion... Comments?
Just for the OP- this could also be an approach to recolor your rail..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
undersc0re (02-16-2013)
Old 02-10-2013, 09:02 PM   #17
Couple of Q's -
Hey Brush...
Have I ever mentioned how much I don't like polyurethane? Doesn't matter, I guess, but I don't. I think it's 6 of one, 1/2 dozen of another contrasting min spirits and den alcohol - I'm pretty certain alcohol works better on waxes, and spirits probably works better on oils - but I know you do a thorough job of prep and whatever the solvent won't remove completely, I'd think the Krud Kutter would...(If there's a concern about solvents, you could always use acetone - or clean lacquer thinner - which usually contains alcohol, acetone & toluene).
After a solvent wash, Krud Kutter wash and light sanding, I'd hope that the WB Zar would adhere to the existing poly without the use of a shellac coat...and speaking of shellac, see below;
WB Zar UltraMax is a Water-borne alkyd (modified poly) - so all rules regarding solvent poly applies. (1) Polys and Shellacs sometimes don't play well together, if you're considering a shellac tie-coat, use Zinsser's de-waxed version SealCoat, (2) check UGL's TDS about the max number of poly coats in an app (usually 3), and (3) watch the re-coat times (re-coat after X hours, but before Y hours) especially since you'll be slightly altering the make up with transtints. How 'bout posting some before and after pics, this topic has come up before and it'd be kinda neat to reference a success story.
and you're right, if the lacquer toner aerosol doesn't work for Underscore, your system might be the best way for him to go...
ric knows paint is offline   Reply With Quote
The Following User Says Thank You to ric knows paint For This Useful Post:
Old 02-10-2013, 09:41 PM   #18
Hey Ric, good job. I respect your knowledge and appreciate your willingness to share it. Thanks.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 02-10-2013, 10:20 PM   #19
Rodger about shellac- by Uni - i did mean the Sealcoat - unwaxed- but I think it's name of Universal Sanding sealer is confusing..
Whats the beef about poly? Spill dem beans bro
The Zar is a wonderful product IMO- best of class for handling in a wb.
And it is also floor rated- so is probably tough stuff.
Thanks!
Old 02-10-2013, 10:44 PM   #20
I agree with RicKnowsPaint. Sometimes lacquer stain is mixed with Hi build clear lacquer to the desired tint, then srayed on the trim. It is cheap and looks great. The downside is that it wears quickly. You can check to see it this is lacquer, put a small amount of laquer thinner on a rag and see it you can soften or remove some of the lacquer. If you can the stain/clear coat is lacquer. You may be able to remove all the red stain with rags and lacquer thinner. Read and follow directions, this stuff can be dangerous.
The stain color appears to be cherry mahogany which is a Blond-it lacquer based stain that has been discontinued 3-4 years ago.
This is a project that may be out of the DIY area. Also consider just replacing the hand rail. You may save time, money, and the smell issues.
Bruntson is offline   Reply With Quote
The Following 2 Users Say Thank You to Bruntson For This Useful Post:
jsheridan (02-10-2013), undersc0re (02-16-2013)
Old 02-16-2013, 12:33 AM   #21
Thanks guys, appreciate the input, I have not tackled it yet, as I would probably spend way too much money on coming home with the wrong tint every time lol. I will figure sumthin out soon, sooo busy at work. Your right about the colour not being stained in, it just wipes off with a warm rag on the slightly worn areas and easily!
undersc0re is offline   Reply With Quote
Old 02-16-2013, 12:42 AM   #22
oops double post darn internet explorer
The Following User Says Thank You to undersc0re For This Useful Post:
oh'mike (02-16-2013)
Latex stain on top of Duron Maxwood oil/acrylic stain? farmery Painting 13 03-12-2013 08:55 AM
Fiberglass door, gel stain, and nervous breakdown wit's end Painting 8 10-26-2011 11:10 PM
Removing stain from deck machouinard Painting 20 09-08-2011 10:12 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 02:57 PM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 12:19 PM
