Stain Or Paint OSB Floor - Painting - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 11:50 AM   #1
stain or paint OSB floor
Hi all, great site, wish I would have found it sooner.
Just finishing up my 30x50 garage build, which I used gambrel roof trusses, that gives me 900 sg.ft. of attic space for storage.
I used 3/4 T&G OSB for flooring.
Now, the garage is built into a bank so I can get my rideing mowers,carts,ect. in. I need to protect my floor from the obvious water, mud and filth, I will be draggin in. I don't know if there is a paint that will hold up to the extream hot and cold of the attic envirerment. I live in SW Pa.
Plus there are chaines on the mower that will probley tear up the paint.
Is there a good stain or paint that will do what I need?
What do you experts suggest?
I need to get this done so I can start filling it up with JUNK
passinthru is offline   Reply With Quote
Old 07-20-2013, 02:41 PM   #2
Gymschu's Avatar
Rewards Points: 822
/Users/jrccshoe/Desktop/sw-carousel-res-flr-image.jpeg
You could use a Porch and Floor Enamel (latex) or an All surface enamel (oil-base) that would hold up to extensive abuse, although the chains on a mower are gonna tear up just about any type of coating on OSB.
Old 07-20-2013, 07:59 PM   #3
Rewards Points: 13,694
OSB was not made to be a finished floor!
It's just never going to hold up even with just foot traffic.
Old 07-21-2013, 04:20 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
Ditto...........
Your going to have to cover it with something....
The attic of my garage is OSB....we have it covered now in some cheap engineered flooring ($0.88/sq ft)....15 year warranty....so far, stuff is doing fine....but the OSB was NOT doing fine before we covered it...
Old 07-21-2013, 06:03 AM   #5
Originally Posted by ddawg16 View Post
Ditto...........
Thanks guys.
I guess I should have thought of this before I used OSB. I sure wasn't planning another 1,000 + on the floor.
When searching SW site,I saw a product called ArmorSeal Tread Plex but its a water base, I don't know nothing about the differance in water base, oil, or latex paints.
If I would paint the floor with something like that, and then put floor covering on the first 10-12 ft. were I would park the mower. Do you think the pant will hold up to lite foot traffic.or am I just wasting my money.
Old 07-21-2013, 06:09 AM   #6
JOATMON
ddawg16's Avatar
It might hold up the first couple of seasons....if your lucky....
There is a pretty good reason you see it called 'sub-floor sheathing' or 'shear wall'.....
You will never see it called 'flooring'................
On a 'positive' note....don't beat yourself up.........................Your not the first one to make that mistake (I was)....and you won't be the last.....
(don't ask me about orientation floor sheathing)
Old 07-21-2013, 07:29 AM   #7
A Little Of Everything
Rewards Points: 1,364
It's true that OSB is not flooring material. However, it's probably good to remember that this is a garage - not a cathedral. Just how perfect does this have to be?
If this were my garage, I think I'd do what Gymschu suggested - coat it with some good oil-based porch & floor paint, and call it good. It won't be perfect, and won't last forever, but it'll be pretty strong. Again, use oil-based paint.
DrHicks is offline   Reply With Quote
Old 07-21-2013, 07:56 AM   #8
OK if I go with the oil base floor paint, can I just sweep, blow the floor off, or would it have to be sanded. If so what would I use? I really don't care what it looks like I just want to protect the floor as long as possable.
How about the epoxy coatings? Anyone know if they would work for me?
Thanks guys for your help.
Old 07-21-2013, 08:00 AM   #9
I'd just sweep it, and maybe use a leaf blower on it. If you start sanding OSB you'll never stop.
You can get gloss oil-base porch & floor paint anywhere they sell paint. Usually runs (currently) $25-$30 per gallon. The nice thing is that when it starts showing wear, you can just roll on another coat.
I have no experience with Epoxy Coatings on OSB, so I won't comment on that.
The Following 2 Users Say Thank You to DrHicks For This Useful Post:
Gymschu (07-21-2013), passinthru (07-21-2013)
Old 07-21-2013, 08:03 AM   #10
DIY staff
Rewards Points: 7,174
No need to sand----vacuum it well and paint it--two coats would offer you a good degree of water protection---plan on recoating every couple of years (in the wear areas---)---it's a storage /service area----not a cathedral.(thank you Dr. Hicks)
Old 07-21-2013, 08:12 AM   #11
Even going over it with 1/2 A/C plywood making sure the seams do not line up with the seams below then using the epoxy on that would work out far better and be far easier
to sweep off.
I once did the floor in a shed I built using strips of parting bead prestained a dark color between the plywood seams. I had cut the plywood in 4 X 4 squares.
I then used three coats of floor poly.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
White stain instead of white paint on a piece of furniture? jbeall Painting 7 01-20-2013 06:47 PM
Stain and polish concrete floor in basement fletchccc Flooring 0 11-30-2012 03:36 PM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
