Stain For New Deck - Painting - DIY Chatroom Home Improvement Forum
Old 09-20-2013, 01:58 PM   #1
stain for new deck
I need to know what the best kind of stain to use on a new pool deck.
I have been looking at Olympic and Cabot, but not sure about what type of stain i need. I dont want the surface to be slick when wet, so what are my options.
Fann is offline   Reply With Quote
Old 09-20-2013, 02:36 PM   #2
cdaniels's Avatar
Is it pressure treated? I'm a big fan of Deckscapes.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 09-20-2013, 02:46 PM   #3
yes pressure treated.
Old 09-20-2013, 03:08 PM   #4
cdaniels's Avatar
I would wait at least six months for the chemicals and water to dry out of new pt lumber before staining it.After that, Deckscapes semi transparent would be my choice.
The Following User Says Thank You to cdaniels For This Useful Post:
Fann (09-20-2013)
Old 09-20-2013, 07:56 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
I use a lot of the Olympic Max toner. I really like how it soaks all the way into the wood, really leaves no film at all. It also doesn't seem to be prone to lifting like Cabbot semi trans can.
I have been getting three solid years out of the Olympic on well prepped decks. It fades out over time. If you restrain often enough, the prep required is usually just a good washing.
After your deck seasons, its a real good idea to wash it, and even sand it lightly, before applying stain. Often, deck maintaince nightmares begin because people assume that new wood doesn't require any prep. This is a false assumption In my experience.
Jmayspaint is online now   Reply With Quote
Deck Stain Help bigmike53 Painting 13 05-29-2013 02:49 PM
used house stain instead of deck stain on a deck yura Painting 5 07-10-2012 05:29 PM
Removing stain from deck machouinard Painting 20 09-08-2011 10:12 PM
Spraying a deck stain hdansjr Painting 3 04-22-2009 12:36 AM
