Stain Brands??? - Painting - DIY Chatroom Home Improvement Forum
Old 08-13-2007, 08:51 AM   #1
Stain Brands???
what's the Best Exterior Stain (for spraing) on Rough Cut Cedar????? I really don;t want to re coat every year. It's going on a Garage & Arbor
mdlbldrmatt135 is offline   Reply With Quote
Old 08-13-2007, 10:23 PM   #2
Paint/Faux Artisan
Da Vinci's Avatar
I prefer Sikkens for it's ability to withstand weather extremes.
BAy Area Painting Contractor
Da Vinci is offline   Reply With Quote
Old 08-14-2007, 12:59 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Rough cedar really needs a brush to force it in there if you want it to last as long as possible
It can be back-brushed after spraying, and before it dries
But it should be brushed
I like Sikkens also, but admittedly haven't used it on rough cedar
I find the water-based Sherwin Williams lacking, the water based Ben Moore a little better
I prefer the oils of Cabot and Ben Moore for rough cedar
The oil-based stains tends to last longer in my local environment also
slickshift is offline   Reply With Quote
Old 08-14-2007, 05:55 AM   #4
I'm in the NE if it makes a difference.............
Old 08-14-2007, 06:05 AM   #5
slickshift's Avatar
I hear from some of my contemporaries in the sun belt that latex can last longer if it's just baking most of the time w/o the extremes we get up here (we can have drastic temp/humid/precip changes within hours, and get the hot sun , cold wet winters, humidity, etc..)
I don't know for sure, but have heard that from some of them
So I have the put qualifiers like "around here" just in case you are in Arizona or something
In your case I can tell you, oil will last longer no question
Old 08-14-2007, 06:07 AM   #6
Agent 000
SecretSquirrel's Avatar
Some of the log home manufacturers and builders use Woodguard. I haven't personally used it on cedar but it has worked well for me on white pine and southern yellow pine. The stain does take a few days to dry out though. And like any stain product it does require periodic maintenance (recoating).
One of the dealers also sell the Sikkens brand that Da Vinci mentioned. Their web site specifically says they have finishes for cedar homes;
http://www.logfinish.com/
PS: You can spray this product but you also have to back brush it.
SecretSquirrel is offline   Reply With Quote
Rust stain on roof krtw Roofing/Siding 15 10-24-2015 05:17 PM
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 10:50 AM
Major screw up: Deck stain usaalways General DIY Discussions 4 07-10-2007 02:39 PM
