Old 10-06-2012, 09:15 PM   #1
Stain
I'm new to this, I was just wondering if anyone knows how to get a deep cherry finish on smooth plywood. I've tried getting it before but it always comes out light. Maybe I'm not using the right brand. Does anyone have any suggestions?
jjessicaa is offline   Reply With Quote
Old 10-06-2012, 09:27 PM   #2
Stain
Did you use a wood conditioner before the stain?
Did you trying applying more then one coat?
Old 10-06-2012, 09:39 PM   #3
Stain
No I didn't try the conditioner, will that help? Yes I did try more than one coat but I didn't let it dry thoroughly between coats, I'm not sure if that makes a difference.
Old 10-06-2012, 11:34 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Stain
I have bad news for you. Plywood will not look like cherry. ( unless you paid huge $ for a cherry ply..)
As far as taking a stain- joe said part of it- it will take very blotchy because most plys are not a quality wood, so you have to even out the porosity ( the conditioner slightly seals the wood to do this) .
But then the wood will not absorb as much stain either- so tinted top coats with stain in the varnish will help.
good luck!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-07-2012, 08:53 PM   #5
Stain
Thanks, I will try that. I am going for a deep reddish brown color but I'm curious to see whatever comes from this. Thanks for your help.
Old 10-07-2012, 09:01 PM   #6
Stain
Other options would be to order some real cherry veneered plywood or just buy the veneer and apply it to the less expencive plywood yourself with contact cement.
Pine is just never going to look much like cherry.
Old 10-08-2012, 11:50 AM   #7
sdsester's Avatar
Stain
You might try a quality gel stain to get the color. It has some opacity to it. Faux finishing with a wood graining tool might work too.
sdsester is offline   Reply With Quote
Latex stain on top of Duron Maxwood oil/acrylic stain? farmery Painting 13 03-12-2013 08:55 AM
Fiberglass door, gel stain, and nervous breakdown wit's end Painting 8 10-26-2011 11:10 PM
Removing stain from deck machouinard Painting 20 09-08-2011 10:12 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 02:57 PM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 06:51 AM
