Spraying Pt Fence - Painting - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 08:15 AM   #1
retired guy
igneous's Avatar
Rewards Points: 137
spraying pt fence
I intend to spray my pt fence soon using a Tradeworks 150 (purchased at SW). I've never sprayed before, so this will be a daunting task. I have approx. 200 linear ft of 6ft high.I am in the process of pressure washing the fence now. I intend to use a solid stain. I will put up a barrier on the side facing my neighbor when I am staying to contain over spray.
Any suggestions or warnings before I begin?
igneous is offline   Reply With Quote
Old 03-15-2010, 02:04 PM   #2
Rewards Points: 526
As much as possible, remember to keep the spray gun perpendicular to the plane of surface you are coating. There is a tendency among new sprayers to start and end a spray pass on an angle, and this where you get a lot of overspray. Have a brush or roller handy to spread out the drips and sags. Paper, tape and dropsheet anything nearby you don't want to coat.
Windows is offline   Reply With Quote
The Following User Says Thank You to Windows For This Useful Post:
igneous (03-15-2010)
Old 03-15-2010, 02:13 PM   #3
retired guy
igneous's Avatar
Rewards Points: 137
Appreciate the advice. Hope to get started as soon as the wood dries out from pressure washing.
Backyard Fence (Part 1) biggidybankston Project Showcase 20 12-04-2010 11:44 PM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 08:05 PM
Spraying a Picket Fence sharingsunshine Painting 1 05-12-2009 06:00 AM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 06:03 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 03:39 PM
