Spraying Ceiling All The Way Down To The Base - Painting - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 07:25 AM   #1
Spraying ceiling all the way down to the base
This is a rental property, I am painting an enitire modular home, 2100 square feet with stucco cathedral ceilings. I was thinking of spraying the ceilings and continuing down over the crown molding, doors, walls and down to the base molding.
I like the look of crown, doors, case and base with semi-gloss.
Should I spray first with a flat, then go back and paint the moldings separately? or spray the same color/finish and then spray the wall a separate color for contrast?
Any thoughts would be appreciated.
misterbreeze is offline   Reply With Quote
Old 12-11-2011, 07:37 AM   #2
Rewards Points: 13,712
Not a great idea to be spraying inside a finshed home. There will be over spray every where.
The only time I see spray used on the inside is before the trim, flooring and doors go in.
Old 12-11-2011, 09:34 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
Ever sprayed before?
You can screw up in seconds what would take many hours to fix.
Think about it.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-11-2011, 03:40 PM   #4
I should have mentioned. Home is empty and there is no flooring.
Another 2x6 cathedral ceiling juststarted Building & Construction 17 11-22-2011 04:27 PM
Installing a ceiling fan in a new construction home HEMMY1244 Electrical 4 09-15-2010 07:11 AM
install ceiling fan in a suspended metal stud ceiling? amp3d Remodeling 2 09-10-2010 07:55 PM
False ceiling... Why? jpelzer Building & Construction 3 06-03-2009 08:01 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
