Spraying ceiling all the way down to the base
This is a rental property, I am painting an enitire modular home, 2100 square feet with stucco cathedral ceilings. I was thinking of spraying the ceilings and continuing down over the crown molding, doors, walls and down to the base molding.
I like the look of crown, doors, case and base with semi-gloss. Should I spray first with a flat, then go back and paint the moldings separately? or spray the same color/finish and then spray the wall a separate color for contrast? Any thoughts would be appreciated. |
Not a great idea to be spraying inside a finshed home. There will be over spray every where.
The only time I see spray used on the inside is before the trim, flooring and doors go in. |
Ever sprayed before?
You can screw up in seconds what would take many hours to fix. Think about it. |
| All times are GMT -4. The time now is 07:34 PM. |
