Old 04-26-2008, 06:59 PM   #1
spraying base already installed.
hey guys, whatsssssssssssssss up.
maybe someone can give me some advise on spraying base.
new construction, I primed everything., walls and trim. Carpenter installed trim and doors.
I was going to spray trim tomorrow (Sunday). Do I need to protect the wall or do I need to tape it off due to over spray. Greco 190es with a fine tip and pressure way down. got that, but the homeowner has me painting eggshell and not sure if the overspray from the trim will show through the eggshell.
sprayer48 is offline   Reply With Quote
Old 04-26-2008, 10:53 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
I would.
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 04-27-2008, 01:30 AM   #3
Pro Painter
You can spray the trim first and paint the walls second. My opinion is that eggshell should always get two coats anyway, otherwise it isn't a true eggshell finish. But thats up to you. If going one coat of eggshell, double cut the areas where you sprayed.
If you spray the trim, make sure it feathers on the wall rather than a heavy line. You may need to sand off some of the gritty overspray.
joewho is offline   Reply With Quote
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 04:46 PM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 07:42 PM
water base poly over oil base poly pappabear Painting 3 08-24-2007 02:53 PM
remove/replace tile over mud base jfm617 Flooring 1 07-07-2007 07:38 AM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 09:29 AM
