Sprayer For Kitchen Cabinets? - Painting - DIY Chatroom Home Improvement Forum
Old 08-27-2015, 11:12 AM   #1
Rewards Points: 44
Sprayer for Kitchen Cabinets?
My wife and I are planning to paint our kitchen cabinets white. I'd like to spray what I can for a better finish. What kind of sprayer should I look to purchase? I do have a 19 gallon Husky compressor with a moisture trap if that helps narrow down my choices.
Appreciate any input/guidance.
bitplumber is offline   Reply With Quote
Old 08-27-2015, 11:40 AM   #2
Rewards Points: 144
What's your budget for the sprayer?I would not look for a spray gun to run off of the compressor.You'll get a quart cup and be constantly refilling and cleaning it.It is also hard to maneuver to spray the inside of the cabinets.I would get a stand alone airless.You will find countless uses for it down the road.
Graco and Titan are two good brands to look into without spending a lot of cash.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
ToolSeeker (08-28-2015)
Old 08-27-2015, 12:49 PM   #3
Rewards Points: 44
Something like the Graco X5? There are some factory refurbs on EB.y for $220 shipped.
Old 08-27-2015, 01:07 PM   #4
Rewards Points: 144
Sorry ,I can't comment on that.I owned a custom cabinet shop for 14 years and now do remodeling.I had very high end equipment in the cabinet shop .Now, doing remodeling I have owned a Graco and Titan sprayers but they are both more expensive units.I can tell you that they are good products with good customer service but can't speak on that specific model.
Old 08-28-2015, 12:03 PM   #5
Rewards Points: 5,974
The 5 will work, but you will need a different tip. They come with a .515 tip and that is too big for cabinets. Do you have experience spraying? If you do you can get by with a bigger tip such as a 413ff. if not go smaller for more control. I personally like the Fine Finish tips from Graco.
Entering your general location can help with answering a lot of times
Old 08-28-2015, 12:09 PM   #6
Rewards Points: 5,336
You might want to rent the high end sprayer you need. You get the sprayer you need without the up front cost of a tool you won't be using too much in the future.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Gymschu (08-29-2015)
Old 08-28-2015, 12:49 PM   #7
Rewards Points: 44
I have a little experience due to home projects. I did paint our house with a sprayer a few summers back and it turned out pretty nice. Thanks for the tip on the tip.
I don't mind spending $220 on a sprayer vs money spent on a rental as we have a number of projects we'd use it for down the road. Thanks for the idea though.
Old 08-28-2015, 01:12 PM   #8
I was talking about a Fuji might mite@ around $600. I'm not familiar with the other one.
Ron
B. Franklin 1759
Old 08-28-2015, 02:13 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 818
I would suggest a HVLP sprayer. You can get a good one for less than $100.
But you will need to thin the paint.
ddawg16 is online now   Reply With Quote
Old 08-29-2015, 12:47 PM   #10
The Hvlp may depend on what paint you plan on using, as stated will probably need thinning. Paints such as pro classic, advance and breakthrough do not take thinning it effects their leveling qualities and can give a streaked look.
Old 08-29-2015, 04:45 PM   #11
Rewards Points: 16
Instead of thinning paint, just use SHER-WOOD KEM Aqua Plus White
Instead of thinning paint, just use SHER-WOOD KEM Aqua Plus White. You can get it tinted to whatever shade you like (e.g., Whisper). It dries much faster than finishes designed for brushing and is very durable. Works great in an HVLP system.
Trekker is offline   Reply With Quote
Old 01-03-2017, 08:56 PM   #12
Rewards Points: 6
Re: Instead of thinning paint, just use SHER-WOOD KEM Aqua Plus White
I am looking to repaint a cabinet with SW kem aqua plus and an hvlp sprayer. Can I use that product on a painted cabinet? Will the kem aqua plus primer work for priming? i know some say you can't use the products unless its bare wood but others seem to say they've used it for refinishing.
stickyfinger is offline   Reply With Quote
Old 01-04-2017, 10:55 AM   #13
Rewards Points: 16
Re: Sprayer for Kitchen Cabinets?
KEM Aqua Plus is a very hard finish. I suspect that SW specifies its use on bare wood due to the difficulty of putting a hard finish over a soft finish.
I've used it over previously finished surfaces that were clean and well-sanded, but those surfaces have all been quite hard.
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 63 01-10-2017 06:50 AM
Adding 12" upper cabinets to already 42" ? DIY-Her Kitchen & Bath Remodeling 10 02-23-2016 01:04 PM
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 07:14 PM
Refinishing old Cabinets ryanb4614 Carpentry 4 08-18-2011 07:24 PM
What sprayer to use to spray some cabinets with SW paint jrs2020 Painting 5 12-13-2009 12:05 AM
