Old 07-09-2009, 09:58 PM   #1
Sprayer Issues
I have a quick question regarding adjusting the output of material. I am using a Graco 490 with a 211 tip spraying General Paints Hi Performance 2000 waterborne. I am spraying trim and doors.
The pressure is set just below half and I am experiencing splatters and too much paint being applied. When I lower the pressure it no longers has a smooth fan. Is there a way to reduce the amount of material being applied?
THANKS
Ageless Trout is offline   Reply With Quote
Old 07-13-2009, 08:28 AM   #2
NAV
Sprayer Issues
I have been spraying for 15 years and spray everything at the highest pressure when using electric pumps. just move quicker and watch your overlaps.
if you like the 1/2 pressure - start with your gun facing away from the area you are spraying (like at the floor) and end with it facing away from the area you are spraying (like at the floor). I know it sucks but it will eliminate your splatter marks.
or you can always just not let go of the trigger. just keep moving - your production will increase significantly. Your quality....not so much.
NAV is offline   Reply With Quote
Old 07-13-2009, 08:47 PM   #3
Sprayer Issues
Thanks Nav,
Great advise and made a huge difference. I added some Floetrol, cranked the pressure up and moved very quickly.
Here is the result.
Old 07-14-2009, 07:23 AM   #4
NAV
Sprayer Issues
Looks good. I spray everything at high pressure unless it is extremely windy & outside of course.
Paint Sprayer Recommendation jpb Painting 2 02-24-2008 02:45 PM
Noisy kitchen sprayer wfischer Plumbing 2 01-28-2008 04:34 PM
Sink Sprayer acting funny... zel Plumbing 3 09-06-2007 06:01 PM
Faucet Sprayer Oswald Plumbing 2 03-29-2006 03:10 PM
