Spray Painting - Painting - DIY Chatroom Home Improvement Forum
Old 06-15-2007, 12:50 PM   #1
Spray Painting
I would like to know if a spray gun, the type used for painting a car, would work with latex interior/exterior paints? I would like to paint my mailbox and other small jobs such a enterior louvered doors. I have a compressor and didn't know if this would work given the thickness of latex paint.
joe3534 is offline   Reply With Quote
Old 06-15-2007, 01:34 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
That depends on what type of spray unit it is
Is that an HVLP unit?
slickshift is offline   Reply With Quote
Old 06-15-2007, 01:56 PM   #3
What is HVLP?
Old 06-15-2007, 02:04 PM   #4
slickshift's Avatar
High Volume Low Pressure
That would be what most would be painting their car with
It can also be use for trim, shutter, doors, stuff like that
They usually have their own compressor, or rather more of a turbine
If it's a cup sprayer you have, and it's attached to a compressor that you use for air tools and such, I wouldn't recommend it for latex
It's technically do-able, but the pressure is so high up to 70% of the paint goes into the air
Not a real smooth finish either
Old 06-16-2007, 11:19 PM   #5
Workaholic's Avatar
Rewards Points: 268
I would think that the cup sprayer with the air compressor would work, the thing is that you might have to thin it down a bit. Most acrilic waterborn "latex" is thick.
Workaholic is offline   Reply With Quote
Old 06-16-2007, 11:20 PM   #6
Workaholic's Avatar
Rewards Points: 268
Sorry, i also ment to add if your only doing small projects like the mailbox, you could also consider an airbrush.
Old 06-17-2007, 07:39 AM   #7
slickshift's Avatar
Originally Posted by Workaholic View Post
I would think that the cup sprayer with the air compressor would work...
You'd think....
I just want to tell everyone from personal experience, don't do it
Technically, it works...the paint can get out of the sprayer
In reality, it does so horribly badly for a bad finish and with up to 70% of the paint in the air not on the surface...it's just a bad thing
Like Nancy Reagan used to say:
Just Say No
Old 06-17-2007, 10:48 AM   #8
Spray Painting
I'ver attached a link for a spray gun and am wondering if this will work with my 6 gal. Porter Cable pancake compresser? I'm wondering if the compressor's CFM which is 3.7 @ 40psi and 2.6 @ 90psi, will work okay with this gun which requires 11 to 13 CFM @45-70psi. Anyone's thoughts?
http://www.harborfreight.com/cpi/cta...emnumber=92841
Old 06-17-2007, 01:03 PM   #9
Workaholic's Avatar
Rewards Points: 268
Originally Posted by slickshift View Post
You'd think....
Just Say No
Well i haver never used a cup on a compressor, but i have used a graco hlvp, it would spray oil decent enough, but in no way could it choak down latex. You had to thin the product a lot. Which is how i think of a cup on a compressor. Actually i pictured a cup with compressor doing a bit better than that hvlp.
Old 06-17-2007, 03:20 PM   #10
slickshift's Avatar
That's not a HVLP rig...
I'm sorry, anything you hook up to your compressor is the wrong type of sprayer for what you need
Old 06-17-2007, 03:24 PM   #11
slickshift's Avatar
...a graco hlvp, it would spray oil decent enough, but in no way could it choak down latex. You had to thin the product a lot....
Correct
Not an ideal situation as the latex must be thinned tremendously
The best way to spray latex is an airless
For a louver door and mailbox, my next choice would be...well, by hand
Frankly, it would take less time to do them by hand than it would to set-up, mask off, clean-up, and break-down a spray rig
But my next choice for a sprayer would be a HVLP with the latex super thinned
A cup sprayer on a compressor would not be on my list
Old 06-18-2007, 04:05 PM   #12
Workaholic's Avatar
Rewards Points: 268
Yeah i would just run an airless rig as well, so i guess the next step then is to do them by hand or go rent an airless from HD. I take Slicks word that a compressor will be worse than the hvlp.
I truly dislike that Hvlp that we had, we ran oil back then and even that was a pain.
Old 06-26-2007, 09:29 PM   #13
made in U.S.A.
Hamilton's Avatar
We just experimented with two automotive guns, one was a cup gun and the other was gravity feed. We used them on a new fireplace mantel.
Of the two the gravity feed was better but overall the finish from both was unacceptable, too dry and textured for our liking.
So out came my ol' "beat to death" airless and, presto, a perfect finish.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 07-02-2007, 02:43 AM   #14
house painter
Joe, if you are painting your mailbox and a couple louver doors in your house you will do just fine with that cheapo harbor freight cup gun.
You will need to thin out the paint quite a bit.
more than recommended on the product can...
but that's ok, it's your house !
Your compressor is small, so you will not be able to spray continuous.
Spray a bit, then let the compressor catch up. Do it again.
After a couple times of that, make sure that it's not overheating.
Do the mailbox first. great practice !
If you don't like it, take it off and blast the paint off at the carwash.
Then you can try again.
r
tmrrptr is offline   Reply With Quote
spray or brush baseboards? mathdan Painting 20 06-05-2015 09:41 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Hairline Cracks after painting parasailing Painting 8 07-23-2006 11:47 PM
Spray painting popcorn ceilings Bill M Painting 3 01-26-2006 03:11 PM
