Old 05-08-2012, 01:44 PM   #1
Spray paint "lifting" underlying paint
I wanted to paint several electric wall heater covers. After I removed them I gave them a roughing up with 60 grit sandpaper. I sprayed the first coat of Rustoleum Universal paint and primer in one. The forst coat worked fine. I waited 2+ hours and sprayed the second coat and, the first coat started to "lift" as if I had sprayed paint remover on it! I called the company and their help dept. indicated that I had not allowed enought time for the first coat to dry. I sanded once again, waited a week and sprayed again--same result! I then started taking the paint down to meatl where the paint had lifted and then, wiped with Acetone. Spraying the third time I now have even more lifting! I have to presume incompatibility of the Rustoleum with the original paint but, what to do???
Karl
karlthev is offline   Reply With Quote
Old 05-08-2012, 02:43 PM   #2
Stop trying to use there "universal paint" just use reguler acrilic. But prime any bare areas first.
Ravenworks (05-12-2012)
Old 05-08-2012, 04:33 PM   #3
Gymschu's Avatar
Could be several factors involved here. It's possible the covers are made of galvanized metal which does not take paint very well. Not likely in this case but you never know. After sanding, did you clean the dust off thoroughly? Basic question, but, that is a huge step to overlook. Also, remember to spray several very light coats instead of a couple heavy coats. Wish I could be of more help.
Old 05-08-2012, 05:53 PM   #4
paper hanger and painter
chrisn's Avatar
The covers need to be absolutely clean, no dust, oil etc.
Are you saying that the covers were already painted?
If so , you don't need the rustoleum.
Old 05-08-2012, 07:10 PM   #5
Karl -
If the 1st coat went on, and did not lift.....I suspect contaminants.
Used Rustoleum over the years. Thin coats. U can out another coat after 30 minutes but not after a hr if I recall (off the can). Enough for the solvent to dissipate and dry. YMMW as I've primarily used their pro cans .
mobiledynamics is offline   Reply With Quote
Old 05-08-2012, 10:05 PM   #6
firehawkmph's Avatar
Karl,
read the instructions on the can. If you wait longer than what they tell you, the paint will dissolve the underlying coat. If you miss the time window, you have to wait 5-7 days for the first coat to completely cure then put on the second coat. I spray the second and third coats as soon as the first coat flashes and is somewhat dry to the touch. It will be a little tacky, but that's allright. Most of the cans will say if you don't recoat in the first hour, wait the 5-7 days. I always use primer first also, not the combined like you stated.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-09-2012, 06:50 AM   #7
Doer of Many Things
poppameth's Avatar
Yep you are outside the recoat window. Generally spray paint should be applied in several thin coats about 15-20 minutes apart and all within a 2 hour window. After that it starts to crackle and lift as it's cured enough to solidify but not enough to prevent the solvents in the spray from loosen it it from the surface. You have to wait several days and sand then recoat if you miss the initial window.
poppameth is offline   Reply With Quote
Old 05-09-2012, 08:06 AM   #8
Thanks for all the advice, MUCH appreciated! Unfortunately, I THINK I've given these all a try...except for a primer coat... Yesterday I sanded the lifted areas flush first by palm sander and then by hand. Final sandpaper was 150 grit. Pretty smooth finish but rough enough (I thought) for good purchase of the paint. I then used Acetone for final wiping with a clean cloth. I figured I'd taken any contaminents off. I used the Rustoleum paint again and, the dang paint lifted within 5 minutes of the spray---looks like painting on paint remover---wrinkled and ready for removal. Now, this didn't happen all over the covers (there are three) but in some areas only. At this point I'm near ready to have the dang things sandblasted and chromed!!! Kidding but.... I'd post pictures here (if that's allowed) but have NEVER posted anything to a website as this so, I'd need some hand-holding to do so....
Karl
Old 05-09-2012, 06:24 PM   #9
Gymschu's Avatar
Karl, and one of the frustrating things about the painting world is that sometimes there is no rhyme or reason to why paint won't stay put. Been doing this painting thing for a long time and every once in a while even after proper prep work, following the right steps, etc. it just doesn't work and what a terrible feeling of frustration.
Old 05-09-2012, 10:43 PM   #10
Karl,
maybe you should try beadblasting the covers and start from scratch. I paint a lot of metal items when restoring my old motorcycles. I beadblast them, blow the dust off, then wipe with wax and grease remover, prime and paint. Maybe that acetone is causing a problem. I don't use any so I'm not sure. You might want to try the wax and grease remover, available an any good auto body supply store.
Mike Hawkins
Old 05-10-2012, 04:52 AM   #11
chrisn's Avatar
Originally Posted by firehawkmph View Post
Karl,
Mike Hawkins
that was my thought also
Old 05-10-2012, 06:53 AM   #12
Doer of Many Things
poppameth's Avatar
Acetone is pretty potent. I wouldn't doubt if it loosened the initial bond.
Old 05-11-2012, 05:55 PM   #13
Resolution (partial). I sanded, let the whole operation sit for two days and then used spray Enamel--Rustoleum but none of the hi-tech stuff. It worked!! Now, I've gopt to go back and resand several times to get all of the mess completely smooth since only hand sanding (and less heat generated) will permit the paint to come off as dust vs globs. Thanks!!!
Old 05-11-2012, 10:11 PM   #14
jschaben
Considering this thread started on the eighth and this is the 11th, and it sounds like you have put on a couple of coats of something trying to fix it.. It doesn't sound like anything involved has had enough cure time to where it should be messed without messing it up more. Throw it in acorner for a week and give it a chance to settle down.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 05-12-2012, 04:17 AM   #15
Good advice to let it settle down however what wasn't conveyed clearly is that the series of paintings/sandings occurred over the course of several weeks rather than days. I agree with letting THIS coat cure sufficiently however.
Karl
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Paint interior with spray gun or Wagner power roller or other? AliceT24 Painting 4 02-18-2011 02:26 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
