Spray Paint Kitchen Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 08-02-2013, 11:21 AM   #1
Spray Paint kitchen cabinets
I would like to spray paint my old wood cabinets. I need some recommendations. Painting after removing from wall, sanded and filled.
What PSI and tank size for a no rush job painting enamel ?
What is the right size nozzle for enamel ?
Water or oil base ?
Do I need to reduce or dilute ?
I have some older DeVilbiss sprayers my father in law used as a professional
Auto Painter. Would they work ?
stymie222 is offline   Reply With Quote
Old 08-02-2013, 02:26 PM   #2
Rewards Points: 12,882
Never spray painted before by the sounds of it.
I'd skip that idea and stick with a foam roller and a 2-1/2 sash brush.
The learning curve is going to kick your butt on this one.
Old 08-02-2013, 03:50 PM   #3
Rewards Points: 5,974
Do not think your auto sprayers will work. The paints are a different composite and take a lot different pressure to atomize and finish right. Having said that I have never tried it so not sure.
Old 08-02-2013, 04:16 PM   #4
Gymschu's Avatar
Rewards Points: 244
Lots of info on this website.......for example: Spraying Kitchen Cabinets
Use the "Search" function and do lots of reading. Spray painting and doing it right is a skill that takes time, patience, and lots of practice to master. You truly will not save as much time as you think you will.
The Following User Says Thank You to Gymschu For This Useful Post:
user1007 (08-02-2013)
Old 08-02-2013, 05:19 PM   #5
I have spray painted before. Just not wood and not enamel.
Thanks for your comments
Old 08-02-2013, 06:39 PM   #6
Too Short? Cut it Again!
Not sure what you actually mean by "enamel" but household finishes tend to be much denser than autobody finishes. An autobody shop will build up many thin layers to get a finish and durable paint thickness.
Since the cabinets are down and you can work with them, you might think about spraying them with autobody finishes. Prep and prime of course. Then build up the paint film thickness with multiple passes and call it a day.
You will need to be sure you have a moisture filter and pressure regulator on the compressor.
I don't think what you have will spray thicker housepaints well but some who spray more may have other comments.
Old 08-02-2013, 06:52 PM   #7
Jmayspaint's Avatar
Rewards Points: 534
Another thing you might look into is pigmented lacquer. If you have some exp spraying auto paint (or something like it), lacquer might not be too hard to get the hang of. It is also thin, and usually applied in fairly thin coats. Your old DeVibiss would work fine with it.
Lacquer will give you a nice finish. It also sands pretty easily, so runs and other bo-boos can be sanded out without too much trouble.
Jmayspaint is online now   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Gymschu (08-02-2013), user1007 (08-02-2013)
Old 08-02-2013, 07:11 PM   #8
As for PSI settings, by the way. I only learned to use airbrushes well so will definitely leave advice on settings for you to the spray guys. If you promise to smash up your car or truck in the next year, and promise the work to the body shop you like, I bet your local guys/gals would help you out. The folks have painted some weird things, and fixed vehicles around lease turn in time for me over the years including appliances where clients wanted just the right kermit the frog green. And they have done wonderful color changing sinks for me.
Old 08-04-2013, 02:47 PM   #9
Rewards Points: 16
Stop by a commercial Sherwin-Williams store. They'll be able to set you up with a good kitchen cabinet finish that's designed to be sprayed. There's just no reason to start with a finish designed for brushing like Benjamin Moore Advance or Sherwin-Williams Proclassic.
If you're spraying without a spray booth, you can shoot a waterborne like Kem Aqua Plus. If you have a spray booth, you can spray an extremely durable finish like Kemvar Plus Conversion Varnish.
As far as your gun goes, you'll just have to pick up the correct aircap and needle. The datasheets are available on Sherwin-Williams website (linked above). As an example, for Kem Aqua Plus:
Conventional Spray:
  • Air Pressure -- 45-55 psi
  • Fluid Pressure -- 8-10 psi
  • Tip -- .055-.070
HVLP:
  • Air Pressure -- 8-10 psi
  • Fluid Pressure --5-10 psi
  • Cap/Tip -- .055-.070
Trekker is offline   Reply With Quote
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 63 01-10-2017 06:50 AM
Best way to paint cabinets robercik72 Painting 9 12-23-2011 07:19 PM
peeling off paint from kitchen cabinets G. allees Painting 2 08-09-2011 05:42 AM
What type paint for kitchen cabinets? Eagle eye Painting 2 07-30-2010 08:00 PM
What's a good price to pay to Paint Kitchen cabinets MTDAMON Painting 2 11-29-2008 06:34 AM
