Spray Paint Interior Doors - Painting - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 11:04 PM   #1
I need to paint 12 interior doors. They already have a white prime coat. I am on a pretty tight budget. Can you please tell me if there is a reasonably priced sprayer I can purchase at Lowes or Home Depot, that would do a good job? Or should I rent a commercial sprayer? Are there any pitfalls that you can mention that I should account for? I am planning on using an interior latex paint if that is the best way to go.
I am going to try to set the doors up vertical in the garage to do the painting, and do about half of them at a time. Thanks..
gwpickard is offline   Reply With Quote
Old 02-14-2012, 04:12 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 146
Why the need to spray? If you have no spraying skill, this could be a disaster.
Old 02-14-2012, 09:43 AM   #3
Good Point
I thought because of the large number of doors spraying would be best. Also the are all 6 panel doors. I thought the 6 panel doors would be hard to paint with a brush without leaving a lot of runs. So with no experience with spraying would you suggest I just do it with a brush and mayber a roller?
Thanks very much for your help on this.
Old 02-14-2012, 11:38 AM   #4
Rewards Points: 12,878
I use a 2-1/2" sash brush for the low spots and a foam 6" hot dog roller for the rest.
Works best of the doors are laying flat. Make sure to remove all the hardware.
Old 02-14-2012, 02:30 PM   #5
ltd
Rewards Points: 536
are they the composite 6 panel doors that have an embossed wood grain on them? if that's the case brush them, you can make those door look beautiful painting them with a broom.im kidding but you get my point.their are some good videos on you tube of painters brushing out 6 panel doors.if they are real wood 6 panel doors, it does take a skill to make them look beautiful.
ltd is offline   Reply With Quote
Old 02-14-2012, 04:01 PM   #6
BraniksPainting's Avatar
I'm going to have to agree with the other guys on this one. If you don't have experience spraying, it could be disaster. Not only that buy why spend 65+ dollars to rent a sprayer. You could have two doors painted by the time you take 6 doors down the basement.
I use a (Purdy) 2 1/2" angle sash brush. Brush out your panels then I like to take a small whizz type roller with a fabric roller skin and roll paint on then the flat surfaces and wipe gently with the brush to knock down the texture of the roller. EXCELLENT results.
BraniksPainting is offline   Reply With Quote
Old 02-14-2012, 09:42 PM   #7
bikerpowell's Avatar
i would rent a commercial sprayer, if you must spray. but i would regularly paint them if i were you.
bikerpowell is offline   Reply With Quote
Old 02-14-2012, 09:46 PM   #8
firehawkmph's Avatar
Rewards Points: 1,800
I do the same thing Joe Caption mentioned. Get a good brush to do the insets, foam roller for the flats. Two light coats. I take a shop vac with a brush on the end and vac the door just before painting. Also make sure the area is clean in general. If you have a bunch of dirt, sawdust, or whatever, some of it will end up in the paint.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-15-2012, 02:29 PM   #9
Too Short? Cut it Again!
You can get a toy sprayer at a box store but you will be disappointed. Rent a good commercial one and buy your own tips to be safe if you must spray.
I agree that a nice angled sash brush is the tool of choice here. Roller cover optional for panel doors as you will probably not save much time on a six panel door over just brushing it out.
If using latex/acrylic semi-gloss I like adding something like Floetrol per the instructions to minimize any possible brush marks.
Old 02-17-2012, 01:05 PM   #10
Send a message via AIM to nathan.hawk Send a message via Skype™ to nathan.hawk
I also do think that using a brush would be a good option. After moving into our home, my wife and I got a few new interior doors (6 panel, composite material) of which we painted with brush (on saw horses). It worked well for us, and it has kept up (well...only been six months). But nonetheless, it works good this way. At least, for us novices, it went well.
nathan.hawk is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
How cold can I spray latex paint? Oh-Fudge Painting 33 11-11-2011 07:05 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
