Spray Or Hand - Painting - DIY Chatroom Home Improvement Forum
Old 01-18-2009, 07:49 PM   #1
Workaholic's Avatar
Rewards Points: 268
It is a matter of efficency. If you are painting x amount of material will it be faster and easier to run the brush and roller vs all the prep work involved to spray. Occupied interior dwelling with furnishings i say brush and roll.
Exterior or new unoccupied area spray it.
I do a lot of new stuff and spray trim and ceiling and closets. I cut in and roll walls.
If i am doing a interior repaint it is 99% quicker to use the brush.
Exterior i like to spray what ever i can.
Sean
Workaholic is offline   Reply With Quote
Old 01-19-2009, 06:02 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
For interiors, it's almost never advisable to spray in an occupied re-paint
(a house with furniture...even if it's a new addition to the house)
For exteriors, it's almost never advisable to spray, unless it's a stucco, textured, or otherwise difficult hand application
(granted the houses in your areas could be way different than in mine)
For a DIYer, it is never quicker to spray, unless it's an empty new const. consisting of the same color on the inside, and/or maybe a lattice, dentil molding, or something on the outside
The prep for spray is intense and the possibility for disaster is high
Unless you've got the knowledge, experience, and systems, for spraying it's no quicker than brush and rolling
slickshift is offline   Reply With Quote
Old 01-24-2009, 07:38 PM   #3
Workaholic's Avatar
Rewards Points: 268
Awww. Thats old school way of thinking. These days lots of exterior work gets sprayed.
It is not always the best method. lots of factors to consider, overspray, efficency, material, prep, ect ect. Yet when the conditions are right, man talk about a time saver. 60% of the time though the factors do not line up and it is brush work.
Sean
spray or brush baseboards? mathdan Painting 20 06-05-2015 09:41 PM
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
Change a door from left hand to right hand? mhaucke Building & Construction 10 10-07-2007 11:18 PM
