Spray Gun Vs Roller Brush - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 07:31 PM   #16
Originally Posted by sdsester View Post
Interesting point taken. If I were trying to preserve the finish on the wall I would work from the bottom up. I would expect to prime over any streaks though if priming and painting.
You stood your ground, but seemingly apologetically. You were right from the start. When you're priming and painting, streaks are no concern, only effectiveness and efficiency. The counterintuitiveness and duplicative effort of cleaning from the bottom up is a price that you must pay to avoid BJ's concern of streak staining. It's far easier, cost effective, and intuitive, to clean from the top down. Why fight nature over a moot point, streaks.
Old 01-25-2012, 02:24 PM   #17
Rewards Points: 119
thank you for all your replies. We have spray painted before and are comfortable with it. Its an empty house so spraying was my first thought. I was once told spraying uses less paint. With my skill level, this has not turn out to be true, but it did get the nooks and crannies that roller and brush wouldn't get. Sounds like there is no 'better' way to do it. Will need to rent the spray gun, so not sure if one can be rented for a shellac based primer. Also not sure if I can rent a respirator.
debd is offline   Reply With Quote
Old 01-25-2012, 03:25 PM   #18
Too Short? Cut it Again!
Then do bite the bullet and buy one with the appropriate cartridges. It will come in handy for other projects. You do not want to be inhaling atomized denatured alcohol.Turn out all pilot lights too please if you are intent on spraying. I hope you don't. I would not.
Old 01-25-2012, 03:45 PM   #19
Rewards Points: 119
Didn't realize they were fairly inexpensive to cheap. Saw a multi-purpose respirators, good for 'Stripping paint/lacquer' among a long list of other things for $50. Any comments on what to look for in buying one.
Old 01-25-2012, 04:27 PM   #20
Standard cartridge size. Appropriate cartridge. Straps that look like they will last more than an hour. Comfortable rubber mask, etc. Overall decent looking and feeling construction. It's important it fit you well or the purpose is lost.
Old 01-25-2012, 04:37 PM   #21
Rubbin walls since'79
Brushjockey's Avatar
Go to a real paint store - tell them what you are doing and ask them to show you.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-25-2012, 05:17 PM   #22
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You can spray shellac through any airless sprayer. I doubt that you can rent a respirator, nor would I want to. They are inexpensive. Buy one. Buy a 3m tape gun, lots of tape, plastic and masking paper as you will need to mask well, especially if you are not that experienced with spraying. Maybe a paint shield too. You will also need to back roll any walls and ceilings that you spray, no matter how smooth you can spray, back rolling is recommended. Spraying usually uses more paint and when you prime and clean the sprayer and gun you loose paint too. Make sure the filters in the gun and sprayer are the appropriate mesh for shellac and that they are clean. You may want a couple of different size spray tips too.
housepaintingny is offline   Reply With Quote
spray or brush baseboards? mathdan Painting 20 06-05-2015 09:41 PM
Brush vs Mini Roller for Cabinets (BM Advance) NickWa Painting 14 01-17-2012 07:25 AM
Techniques and tips EvilNCarnate Painting 5 01-11-2012 06:53 PM
Paint interior with spray gun or Wagner power roller or other? AliceT24 Painting 4 02-18-2011 01:26 PM
Should I spray or brush? billyg Painting 5 01-24-2008 06:51 PM
