Spot Priming Without Flashing ? - Painting - DIY Chatroom Home Improvement Forum
Old 03-10-2015, 10:10 AM   #1
Rewards Points: 8
Spot Priming without Flashing ?
Hi Folks,
I'm looking for product / application suggestions for some interior walls that I'm getting ready to paint. The walls have a late 1950's sand texture brushed on finish, and I've patched some nail holes and gouges w/ spackle & JC and sanded them.
I want to spot prime the patched areas and top coat without them flashing. Walls currently are Dead Flat White El-Cheapo latex, new top coat paint is going to be 2 coats of Kilz 330 Eggshell White (this is a rental property).
I was thinking of using Kilz Original (oil base) for the spot primer, but not sure if I should go w/ Latex primer instead. I haven't used the Kilz 330 Eggshell before, but folks have said that it has a lower sheen than some other brand Eggshell's, so I'm concerned that the sheen of the Oil based kilz may flash. The Landlord really does not want to prime all the walls.
I'm sure this has probably been answered before and apologize if it has, but I'm in a bit of a time crunch and would appreciate any info you may have to offer.
Thanks,
YB
Yankee Bill is offline   Reply With Quote
Old 03-10-2015, 12:33 PM   #2
Gymschu's Avatar
Rewards Points: 460
The key is to keep the "footprint" of your patches small. In other words, for a nail hole you don't want a 1 foot x 2 foot area of spackle/mud to spot prime. Keep the area as small as possible without causing a hump.
Sand the spots well, remove the dust. I like to spot prime with a regular drywall primer (latex). I might hit the spots 2 or 3 times to allow for that bit of soaking in that occurs with patches. Once dry I hit them once with the topcoat paint. Allow to dry. Then two coats of paint and you will never see where the patches were.
That's just one man's approach. Others may have other secrets that would be more to your liking. I've done apartments for 36 years and this has worked for me for all those years.
Giving us your general location helps us better help you!
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
Sir MixAlot (03-10-2015)
Old 03-10-2015, 01:35 PM   #3
Rewards Points: 8
Thanks for the info Gymshu. I don't mind buying some latex Drywall primer, but I already have some of the Oil base Original Kilz on hand, do you think that might have too much sheen to use? I'm kinda thinking it might.
Appreciate your help.
Thanks,
YB
Old 03-10-2015, 02:05 PM   #4
Gymschu's Avatar
Rewards Points: 460
The oil base produces a very nice seal, but because of its slight sheen it produces its own set of flashing issues, so yes I would use a latex-based drywall primer for best results.
Old 03-10-2015, 02:12 PM   #5
Rewards Points: 8
Yeah, that's what I was figuring as well. But it's always reassuring to hear it from a Pro
Do you have a preferred Drywall Primer that you'd care to share?
Thanks again for your help, I really do appreciate it.
YB
Old 03-10-2015, 04:23 PM   #6
Gymschu's Avatar
Rewards Points: 460
Sheetrock USG makes a good one or Sherwin Williams/Benjamin Moore.
Old 03-10-2015, 08:01 PM   #7
Rewards Points: 1,015
I'm in a similar situation w nail pops and patches on a room I'm doing. I plan on using Zinsser 123 latex. I have a small brown water stain mark that I was going to spot prime twice before doing a full coat of primer on the ceiling.
I didn't want a sheen either. Would you guys recommend using the Zinsser 123 spot primed twice? Or do I need an oil based primer just on the brown spot?
cjaustin81 is offline   Reply With Quote
Old 03-10-2015, 08:46 PM   #8
Jmayspaint's Avatar
Rewards Points: 534
The 123 will probably be fine for that little stain, but if you want to be more sure you could hit it with a spray can of oil primer. That's what I would probably do, but then again I pretty much always have a can handy. Likely not totally necessary.
Something like one of these
Jmayspaint is online now   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Gymschu (03-10-2015)
Old 03-10-2015, 08:49 PM   #9
That's a fantastic idea. I think I'll give that a try.
Thanks.
Old 03-10-2015, 09:35 PM   #10
Jmayspaint's Avatar
Rewards Points: 534
Thanks.
Those spray cans are handy. I try not to get the oil primer out these days, it's being phased out of residential work anyway. But as good as some of the WB primers have gotten it can be hard to trust them totally, for me anyway. The spray cans are an easy way to ensure small potential trouble spots aren't a problem.
For the OP, I might consider using a spray can for something like your patches if there weren't many of them. I've had mostly good luck using the Coverstain spray for touch up priming on flat painted walls and ceilings. It dries down fairly flat, and doesn't seem prone to flash.
Old 03-10-2015, 10:46 PM   #11
Rewards Points: 8
Thanks for the additional input guys. I ended up getting a gallon of Kilz PVA Drywall primer. Got 2 coats of it on the patched areas so far.
It actually matches the existing Dead Flat White Top Coat finish that is already on the walls so well, that now, the Landlord is thinking of having me just touch up the whole apartment with it and not even repaint the place with the Kilz Pro-X 330 Eggshell, as we had originally planned. Gonna wait and see how it looks in the A.M. to decide that though.
YB
The Following User Says Thank You to Yankee Bill For This Useful Post:
Gymschu (03-11-2015)
Will be priming entire area -- should I spot prime repairs first? Rav Painting 1 02-21-2015 05:58 PM
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 12:53 PM
Need help deciding giving this chimney flashing contractor a second chance tracyj Roofing/Siding 3 03-29-2011 10:56 AM
proper steps in wrapping tyvek and flashing windows?? 4just1don Building & Construction 4 11-17-2008 07:10 PM
Flashing problems Slave Building & Construction 3 11-16-2005 04:56 PM
