Splotchy Paint On New House Causes? - Painting - DIY Chatroom Home Improvement Forum
Old 12-07-2015, 09:38 PM   #1
Rewards Points: 2
Splotchy paint on new house causes?
My fiance and I recently purchased our first home we absolutely love the home however we noticed during the initial walkthrough and more so now that were in the two sun facing sides of the house have a very splotchy paint covering almost a tan camo.
My question is we intend to repaint but I want to ensure that proper preparation is taken so as not to see this effect again my assumption is most likely the mixture of oil water in the paint was incorrect causing some areas of the paint to fade quickly. Unsure when the house was last painted could be original paint from 2001.
Thank you!
Check album for picture
jbailey is offline   Reply With Quote
Old 12-07-2015, 10:48 PM   #2
Rewards Points: 6,652
Bad paint and bad paint job is why you have the problem. As for the direct Sunlight, suggest that you get tinting done on those windows that are getting the most Sun.
If you want to know what you need and the proper paint. Any Sherwin Williams store can supply you with everything you need.
Every paint will fade if exposed to direct sunlight.
Old 12-08-2015, 06:52 AM   #3
Gymschu's Avatar
Rewards Points: 678
Could have been caused by dozens of things. Cheap builder's paint, poor prep, paint not mixed well, poor rolling/spraying/brushing technique, etc. Sand it well, remove any dust, prime (not necessary unless it's really bad), and repaint (2 coats). I like Gregzoll's idea of tinting the windows to reduce the UV rays on some of your walls.
P.S. Oil water? Very few paints today contain any oil.
Giving us your general location helps us better help you!
Old 12-08-2015, 07:02 AM   #4
Rewards Points: 1,382
$50.00 says it was Sherwin Williams to begin with. $100.00 says it was Promar 200.
klaatu is offline   Reply With Quote
Old 12-08-2015, 07:36 AM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
I believe she's talking about the exterior of the home, so It could not be promar. Even if it's sherwin Williams there are numerous reasons why this happened.
housepaintingny is offline   Reply With Quote
Old 12-08-2015, 04:43 PM   #6
Gymschu's Avatar
Rewards Points: 678
Oops, I should've looked at the album first. The picture (to me anyway) looks like the former owners did a spot paint job in order to make the house look presentable for sale. Probably used some leftover paint that NOW doesn't match due to the paint fading on the sunny side(s) of the house.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
gregzoll (12-08-2015), ToolSeeker (12-12-2015)
Old 12-08-2015, 04:59 PM   #7
Rewards Points: 2
Yes, these all seem like reasonable suggestions. Obliviously the problem is not common enough to pin point precisely. I will likely have someone come out and look at it to be sure it nothing beneath the paint like the siding or moisture that is causing the differentiation. It has more of a rounded look like water marks rather than straight lines that of a touch up.
Old 12-08-2015, 06:02 PM   #8
Rewards Points: 13,468
No over hang on the roof, sunny side of the house.
Any paint going to have a tough time.
A quality paint will make it look brand new.
Old 12-09-2015, 07:21 AM   #9
Rewards Points: 268
If this my was house or a house for a client i would pressure wash the side of your house. Let it dry for a complete day or 2. I would repaint the sidding in either satin or matte depending on sheen you want. Make sure you use a good quality paint.
Recommendations:
Sherwin Williams Emerald, Resilience or Solo if you want to save a couple $$
Dulux Diamond Exterior.
Here are links to paint i mentioned to help you out
Sherwin
Emerald http://www.sherwin-williams.com/docu.../035777107843/
Resilience http://www.sherwin-williams.com/docu.../035777820698/
Solo http://www.sherwin-williams.com/docu.../035777042922/
Dulux
Diamond http://www.dulux.ca/PPG/Dulux/Media/...R.pdf?ext=.pdf
http://www.dulux.ca/PPG/Dulux/Media/...t.pdf?ext=.pdf
AlphaWolf is offline   Reply With Quote
Bought a flipped house, appears latex paint hastily applied over oil wrestler Painting 3 07-03-2014 06:49 AM
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 05:19 PM
Paint advice for an entire house with new and old surfaces rightit Painting 5 10-01-2012 08:49 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Why shouldn't I paint my house exterior in Duration gloss? skiposwald Painting 7 07-10-2009 09:23 AM
