Splotchy Paint After Patch Job - Painting - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 10:32 PM   #1
Splotchy paint after patch job
So when we bought the house, the previous idiot had punched a hole through the wall between the garage and the living room...about 1.5" in diameter. I spackled and painted with a matching color (matched perfect on other parts of the wall), but in this section there was a dark stain where I painted.
I thought, maybe it needed to be primed, so I primed the area and painted it again, this time parts of it are the right color, but it's still splotchy and dark in places around where the hole was.
Any remedy to this short of repainting the entire living room? Thanks!
robwallis is offline   Reply With Quote
Old 02-26-2009, 07:39 AM   #2
Remodeling Contractor
You need to cover patches with a sealing primer or they "flash" which gives a modified sheen to the paint. Which is why you still see it.
Old 02-27-2009, 01:29 PM   #3
Thanks. Would an oil-based primer seal better? I'm painting with Latex. How long should the primer dry before painting? Can you recommend a brand?
Old 02-27-2009, 01:33 PM   #4
Rewards Points: 506
What paint and primer have you tried already? I have had good luck with SW PrepRite ProBlock Latex. Dries in an hour and is water-base. There is no need to use an oil-base here, just a water-base that doesn't suck. (i.e. Avoid Kilz2/Premium at all costs)
SirWired
sirwired is offline   Reply With Quote
Old 02-27-2009, 01:33 PM   #5
I would use Benjamin Moore's First Coat
Old 02-27-2009, 02:26 PM   #6
The paint is Lowe's Valspar, the primer I tried is Glidden Gripper. Didn't do much.
Old 02-27-2009, 02:30 PM   #7
you said have told us that to start with.. Cheap paint.... poor job.. that is all there is to it. Use SW or BM paints
Old 02-27-2009, 02:34 PM   #8
Rewards Points: 506
Youch. Yes, first, get a refund for the paint and primer. No excuse for flashing after primer + 2 coats paint. Next, have an actual paint store match the color, based on the Valspar color code, prime the whole wall with paint-store primer and re-paint the wall. It will probably not be an exact match with the other walls, but it should be close enough.
Or, you could get another gallon of the Valspar for free (the store shouldn't give you flack on it) and try another coat of the cheap paint.
SirWired
Old 02-27-2009, 06:00 PM   #9
Tired, Cold, and Damp
slickshift's Avatar
Ditto on the better quality primer and paint
slickshift is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
