Spider Web City Popcorn Ceiling, Yuck! - Painting - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 01:07 PM   #1
spider web city popcorn ceiling, yuck!
this house has those popcorn looking ceilings on all 1800 sq ft. I have tried to sweep it before repainting, but it just smears the webs. I dont like this type of ceiling really, but is it a ton of work to remove it. This house was built in 1991 so it shouldnt have asbestos in the "popcorn". Are popcorn ceilings in style or should i tear it all down....any comments? I am an over ambitious woman who is trying to redo her house on a tight budget
hopethechestnut is offline   Reply With Quote
Old 01-11-2012, 02:50 PM   #2
Gymschu's Avatar
Rewards Points: 932
Hope, there are literally dozens of topics on here about popcorn ceilings........do a search and you will find hundreds of posts about it. Popcorn can be removed......sometimes it comes off easily, sometimes not. A 6-inch broad knife is your friend for a project like this. Once you get a spot scraped off you can aggressively scrape down to the bare drywall. That's if it comes off easily. I have seen popcorn that seemed to be bonded to the wallboard and had to be continuously wetted and then scraped off making a huge mess. Like I said, read through many of the posts by using the search function......that's a great place to start.
Old 01-11-2012, 03:41 PM   #3
I can fix that!
Rewards Points: 35
I would like to meet the guy who decided popcorn ceiling texture was a good idea back in the day
kuhlman is offline   Reply With Quote
Old 01-11-2012, 04:27 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 488
I do believe he was murdered
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (01-11-2012), jsheridan (01-11-2012)
Old 01-11-2012, 05:47 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
I think he was a taper..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (01-12-2012)
Old 01-11-2012, 08:18 PM   #6
ltd
Rewards Points: 536
hes probably the same who invented silicone caulk
ltd is offline   Reply With Quote
The Following 2 Users Say Thank You to ltd For This Useful Post:
chrisn (01-12-2012), Gymschu (01-12-2012)
Old 01-17-2012, 07:31 PM   #7
Removing a popcorn ceiling, whether removing it by wetting it or not, will result in a huge mess.
It's save to say popcorn ceilings are out of date. Hopefully yours has not been painted over previously making removal easier.
CB Painters is offline   Reply With Quote
Old 01-17-2012, 07:42 PM   #8
Rewards Points: 526
Popcorn texture is usually easy to remove (in my experience), -- but it may take a lot of time and effort to make the underlying substrate into a finished ceiling.
Windows is offline   Reply With Quote
Old 01-17-2012, 09:10 PM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
Yep, he was murdered along with the guy who invented wallpaper.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 01-18-2012, 03:58 AM   #10
chrisn's Avatar
Rewards Points: 488
Hey now, no need for that
Old 01-18-2012, 10:29 PM   #11
Wallpaper is evil. No good has ever come from wallpaper
Old 01-19-2012, 02:45 AM   #12
chrisn's Avatar
Rewards Points: 488
It pays my bills, that is a good thing
Old 01-19-2012, 10:53 AM   #13
Too Short? Cut it Again!
As mentioned before, popcorn ceilings are the work of the devil. Except for those done right and that do have SOME accoustical properties, they were popular because they saved having to properly tape and finish the ceiling drywall. Most were put on without a primer and the slurry contained the cheapest paint money could by. Eventually they will likely start failing so if you do not like them, nobody will fault you for taking them down.
I think you will find it goes fast with a wide drywall blade. I used a Fein oscillating tool that made short work of the few stubborn spots. Others suggest a wet method and a garden tank sprayer would be handy for that.
It is a mess though so make sure you have tarps and contractor trash bags on hand.
Old 01-19-2012, 10:55 AM   #14
Nothing adds an element of class like a nice wallpaper in the right situation. And if applied properly it should be easy to remove if you don't like it.
Now those stupid looking wallpaper borders are evil!
popcorn ceiling (resurfacing) bryanp Painting 3 08-25-2011 05:16 AM
crown molding on popcorn ceiling beech Carpentry 7 02-07-2011 07:23 PM
Question About Redoing a Popcorn Ceiling... angie59 General DIY Discussions 15 10-16-2008 09:46 AM
Popcorn ceiling has been removed, white powder on sills? daz59 General DIY Discussions 19 06-26-2007 06:28 AM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 01:33 PM
