Spackling Problems - Painting - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 10:39 AM   #1
spackling problems
Why when I spackle and it drys do I get little tiny pin holes in it, what am I doing wrong? Also, what is the best and easiest spackle to use under paint when painting drywall?
aspen1102 is offline   Reply With Quote
Old 02-22-2009, 11:06 AM   #2
the Musigician
DangerMouse's Avatar
is this something you mixed yourself? seems to me you have air bubbles in it.
DM
Old 02-22-2009, 11:09 AM   #3
No it is the ready mixed blue lid container from home depot!
Old 02-22-2009, 11:20 AM   #4
the Musigician
did you stir it up first? had it settled?
DM
Old 02-22-2009, 11:29 AM   #5
Yes it was stirred before we used it.
Old 02-22-2009, 11:47 AM   #6
the Musigician
stir it again SLOWly and then 'thunk' the bucket on a cement or sturdy floor a bit to help release the air bubbles and try a small area again.
DM
Old 02-23-2009, 02:36 PM   #7
Drywall contractor
Rewards Points: 1,070
How heavy are you applying it?? A couple of thinner coats is best, as opposed to trying to get it to cover in one coat. Different brands have different color lids....... Is it lightweight compound?? That generally tends to "crater" worse than regular ready mix. (And does not dry as hard.) Are you applying it over a painted surface?? It will tend to crater more on paint, especially a gloss paint. Really not much you can do in that case but sand and re-coat.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-23-2009, 02:45 PM   #8
the Musigician
bjb, you think it maybe should just be thinned first, and gently stirred? i'd think that would do it.
maybe still thump it a few times...just to release agression... -=chuckle=-
DM
Old 02-23-2009, 03:10 PM   #9
Drywall contractor
I've just never really been a fan of the lightweight stuff in general. I think it's just "the nature of the beast" for it to crater. The few times I've used it (someone else furnishing material) thinning didn't seem to help. Really can't say I've tried your "thumping" strategy.......might work though. I use the old "squirt of dish detergent" method which seems to do ok. Main problem I found with lightweight is that it's softer than regular mud. You can scratch it easily.
Old 02-23-2009, 03:20 PM   #10
the Musigician
i guess that leaves it at a "hurry up and paint me" stage, eh?
DM
Old 02-23-2009, 03:31 PM   #11
Drywall contractor
Yeah, pretty much. And again, to each his own. There are folks who swear by the lightweight mud.
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
