Spackling Problem - Painting - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 08:47 PM   #1
Rewards Points: 180
Spackling problem
I am prepping a wall to paint it. Today I filled all of the dents & dings with spackle and now there are two textures on that wall - the original texture from the old paint being rolled on and now the spots of smooth texture where I sanded the spackle off.
What can I do to fix this? I'm pretty sure it's going to look bad after being primed and painted.
Thanks for taking the time to read this.
Barb
gma2rjc is offline   Reply With Quote
Old 07-06-2011, 08:53 PM   #2
Workaholic's Avatar
Got a picture of the problem?
Sean
Workaholic is offline   Reply With Quote
Old 07-06-2011, 09:27 PM   #3
Rewards Points: 180
I'll get one tomorrow when the sun is shining in on that wall, showing the flaws.
Barb
Old 07-06-2011, 10:38 PM   #4
It sounds like you're anticipating a texture flash, where the patch area is smooth in contrast to the surrounding texture created by the roller previously. If you're not using a sheen finish, or you don't have strong sidelighting, you shouldn't have much problem, as flats generally don't reveal a texture contrast that obvious. Other than spot priming with a roller to add a bit of texture, don't use a brush or you'll make it worse, there's not much you can do. There was a bit of discussion about this topic in another thread, type texture flash into the search engine. It was fairly recent.
The Following User Says Thank You to jsheridan For This Useful Post:
gma2rjc (07-06-2011)
Old 07-06-2011, 10:58 PM   #5
Rewards Points: 180
Thanks jsheridan. Unfortunately, I won't be able to use a flat paint because of the fingerprints and dirt from hands that gets on that section of wall. It's a small section next to the stairway and has to be washed fairly often.
During the day, when the front door is open, there is side lighting that shows imperfections. But I like the idea of using a roller to apply the primer. I'll use one for the paint too and maybe the flat spots won't be as apparent.
Thanks again.
Old 07-06-2011, 11:38 PM   #6
ltd
Rewards Points: 536
if its small dings ,dents ,smaller than a quarter,i would just spot prime with finish paint with your brush .then roll finish paint ,i do this daily no problems. also if you dont look for the patches you wont see them.wow that's profound
ltd is offline   Reply With Quote
The Following User Says Thank You to ltd For This Useful Post:
Old 07-07-2011, 12:01 AM   #7
Rewards Points: 180
Here is a link to the thread I believe you're talking about:
Walls are "Patchy" when viewed at an Angle
Old 07-07-2011, 01:01 AM   #8
Workaholic's Avatar
At first I thought we were talking about a textured wall, if it is a smooth wall do your repairs sand smooth, spot prime and paint the wall.
Sean
The Following User Says Thank You to Workaholic For This Useful Post:
gma2rjc (07-07-2011)
Old 07-07-2011, 01:06 AM   #9
Rewards Points: 180
You were right, there is a texture. It's from the paint being rolled on. It doesn't really stick out, but it's noticeable when there are smooth spots here and there.
Thanks.
Old 07-07-2011, 01:25 AM   #10
Workaholic's Avatar
Thanks.
Prime with a roller like J suggested and after you are done painting the entire wall it should blend in fine. If you are really using spackle and not drywall mud I recommend priming your repairs twice, spackle tends to flash more.
Sean
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
