Old 02-27-2013, 12:33 PM   #1
Spackle Questions
Prior to actually painting - Do I need to prime the areas where I used spackling paste to cover nail holes and gouges in the walls? if so, what's the best product to use?
Also, I know the pros don't like the big box stores but is all spackle pretty much the same? Would I be safe just getting in a Home Depot or Lowes? If not - what's the brand name to look for?
Thanks!!
dschribs is offline   Reply With Quote
Old 02-27-2013, 12:58 PM   #2
cdaniels's Avatar
Spackle Questions
Yep prime it.Zinsser 1-2-3 is a good choice for spot priming and the spackle you buy at the box stores is ok but you may need to go over it more than once to get it filled in completely as it has a tendency to shrink when it dries.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Gymschu (02-27-2013)
Old 02-27-2013, 05:51 PM   #3
Spackle Questions
What kind of paint, and what sheen will you be using, and how many coats?
jeffnc is offline   Reply With Quote
Old 02-27-2013, 05:57 PM   #4
Spackle Questions
Ben Moore. Two coats. Eggshell sheen
Thanks!
Old 02-27-2013, 06:03 PM   #5
Spackle Questions
What kind of Ben Moore? With eggshell you usually want to prime/seal first.
Old 02-27-2013, 06:05 PM   #6
Spackle Questions
Don't know if cdaniels is implying that box store spackle shrinks and "other" compound doesn't, but basically that's not true.
Old 02-27-2013, 07:15 PM   #7
Spackle Questions
I didn't get that at all. All spackle shrinks. But here's a little tip, don't use your finger or thump to apply the spackle. Use a flexible putty knife. The reason, look at the end of your finger it's round when you push the spackle in that puts it below the surface and you end up with a small divot.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
cdaniels (02-27-2013), Gymschu (02-27-2013)
Old 02-27-2013, 07:35 PM   #8
Spackle Questions
Actually, I was wondering if there was a good way to do the opposite. i.e. it would be easier (faster) to leave a bump there and sand it off, than to have to apply 2 (or 3) flat coats that shrink. Does anyone do this?
Old 02-27-2013, 08:24 PM   #9
cdaniels's Avatar
Spackle Questions
Jeff,what I meant was All spackle/joint compound shrinks.I some times do leave it built up so I can sand it down smooth in one application.Depends on the size of the hole usually.
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Mobile Home Carpentry questions immeraufdemhund Carpentry 3 11-19-2010 07:52 AM
Newbie with questions about a 4 ton rheem nissan4x4 HVAC 4 05-25-2010 12:53 AM
A few roof questions before I begin... chrisexv6 Roofing 6 05-02-2010 07:16 AM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
