Spackle Or All Purpose Compound For Tons Of Popped Screws - Painting - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 08:01 PM   #1
crankcase's Avatar
Spackle or all purpose compound for tons of popped screws
I am getting ready to paint the laundry room of our house that was built in July and am running into a ton of popped screws and dings that I didn't notice until now. What will give me a better finished look with this much patching? Spackle or all purpose mud? I am going to now have to re-prime the whole room to seal up my patches for an even paint color so what will give me the best results? I'm not calling the contractor to screw this one up again.
Spackle or all purpose compound for tons of popped screws-002.1.jpg   Spackle or all purpose compound for tons of popped screws-003.1.jpg
crankcase is offline   Reply With Quote
Old 03-25-2011, 08:18 PM   #2
All purpose joint compound will do the trick.
Old 03-25-2011, 09:06 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Agree- all purpose. It is just like it was new rock with naked screws now. It will take 2x to fill them , use a hand sander or pole, not a sponge to sand so it is flat in the end.
Complete reprime is the only way to go here.
Brushjockey is offline   Reply With Quote
Old 03-25-2011, 10:57 PM   #4
Registered User
Rewards Points: 5,514
Now that the studs are really drying out because of the winter heating, it should be under builder's warranty..... or at least get compensated for the material.
http://www.paintsource.net/pages/sol...ood_shrink.htm
Gary
Old 03-26-2011, 03:18 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 392
Just curious. Didyou apply any of those screws? I have never seen doubled up screws like that.
Old 03-26-2011, 09:26 PM   #6
Too Short? Cut it Again!
Me either and same question. And if so many screws are coming out, how wet was your framing lumber when the house was built? I have experienced drywall nails, back when they were used, popping out like bullets from wet douglas fir timber as it dried. But more likely, did you or your contractor seat the screw heads below the surface of the drywall?
Direct answer to your question? On new construction and once you seat the drywall screw heads under the surface o at least create some dimples? Drywall compound.
Spackle is worthless expensive crap that students use to try to patch their student apartments and get Mom and Dad's deposit back. It has no dimensional stability. I've never been able to work it. A little container is like $5 retail. My cost for five gallon buckets of drywall mud was the same.
I am out of the painting business now but when I was in it? Many of my clients were at galleries and great at poking all sorts and sizes of holes in walls. I loved both pre-mixed (if you have the time for it to dry) and dry/hot mix drywall compound. Among other things, you can wet sand it with a sponge.
Old 03-27-2011, 08:29 AM   #7
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
Crankcase, I would use all purpose for sure.
You should be able to just spot prime the newly mudded areas only.
And, If your going to prime the whole room, still spot prime those areas first.
-Paul
Chris, from the picture it looks like some of the screws were sunk to far past the paper and another screw was added either during construction or recently by the H/O.
-Paul
Sir MixAlot is offline   Reply With Quote
Old 03-27-2011, 10:26 AM   #8
the Musigician
DangerMouse's Avatar
It looks like there is only one screw, not two, in each area.
They popped out, so the OP (or someone) unscrewed them and raised/lowered each one.
Fill both holes and hope it doesn't do it again.
DM
spackle versus joint compound... joeyboy General DIY Discussions 13 01-06-2016 05:09 PM
Spackle Properties and favorite topping compound mobiledynamics Drywall & Plaster 0 08-22-2010 08:32 PM
Use joint compound, spackle, something else?? tracyballard Carpentry 0 06-08-2010 10:39 PM
Used spackle instead of joint compound on a wallboard repair--help TytusDwn General DIY Discussions 4 10-25-2009 03:43 PM
Joint Compound Vs. Spackle Rze Painting 5 09-14-2007 11:09 PM
