Soot From Grease Fire, Errr - Painting - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 04:53 AM   #1
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
soot from grease fire, errr
Hello everyone, had a grease fire about a week and a half ago, rediculous amount of soot everywhere. Have already cleaned walls with Tsp and alot of elbow grease and rinsed multiple times,The dry sponges for soot arrived today for my ceiling. First time dealing with aftermath of fire, so any suggestions, advice, or opinions are welcomed and appreciated.thanks in advance . Plan is to shopvac then drysponge the cealing best I can, vac again then use shellac based bin to seal ceiling and the two spots on the wall up high, bullseye123plus for all the walls, got all the sealer and primer and cabinets today. Ill pick the paint up later in week. Am i on the right path
Sent from JC using DIY Chatroom
jpc is offline   Reply With Quote
Old 10-04-2013, 01:32 PM   #2
Gymschu's Avatar
Rewards Points: 212
Definitely on the right path. I have done insurance claims for homeowner's in the same boat as you.......they had professional cleaning services come in to do the work of removing as much soot as possible. As you are finding out, there's no way to get it all so BIN or Cover Stain are your friends. The 1-2-3 will not be as effective as BIN in covering the soot so you may want to consider using BIN or CoverStain on the walls. CoverStain is less expensive than the BIN.
Gymschu is online now   Reply With Quote
Old 10-04-2013, 04:43 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
yes^^^^
Old 10-04-2013, 09:10 PM   #4
jpc
jc
Rewards Points: 162
Thank you , while I'm out pickin up other material ill swap that 123 out for some more bin and coverstain, whole I was waiting on the sponges I started on the walls, in a couple spots accidentally over sprayed into the ceiling and it immediatly obsorbed it leaving a dark stain, how do I tackle that one? I really appreciate your help and time
Old 10-05-2013, 08:27 AM   #5
Rewards Points: 5,974
the BIN should handle it.
Gulf Island Building. cocobolo Project Showcase 8228 11-17-2015 03:02 AM
Stripping off old paint blwegrzyn Painting 71 11-28-2013 01:43 AM
Concrete Fire Pit Project - Advice polizei11 Concrete, Stone & Masonry 2 11-13-2012 03:34 PM
removing smoke & soot from brick fire place - extensive fire damage in house Hargrove Remodeling 2 06-09-2011 05:37 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 09:38 PM
