i had a tenant that used kerosene inside for heat. that was approx. 7 months ago. i cant scrub it off to paint. have tried t.s.p., clorox, windex, multi surface cleaner. what do i use to be able to paint this apt.?
I had a similar issue with heavy tabacco smoke stains.
If you used the alcohol based primer, don't wait too long to paint the finish coat of paint. After a couple days, it a while it dries hard and is hard to cover with latex.
Which ever method you use, make sure you have proper ventilation and use a mask.
Before you paint over anything, thereby sealing the soot into the wall, try using a damp Magic Eraser. I expect that will remove the soot better than anything you've tried so far.
You should be able to find Mr. Clean "Magic Erasers" at most grocery and hardware stores. I find that the No-Name Brand equivalents called "Magic Cleaning Pad" are just as good, but lower in cost.
The problem is that you're dealing with particulate matter that is on a rough surface, and the different cleaners you used simply won't dissolve "soot". Nothing will dissolve soot. It has to be removed mechanically, and sponges and rags have fibers far too large to get into the tiny crevices on the surface of paint. Magic Erasers are made from a foam with excess blowing gas to that the structure formed consists of extremely fine branches which can get into the surface roughness of the paint.
Buy quite a few Magic Erasers. The foam they're made of is very hard and it tends to break as you use the Magic Eraser. The result will be that the Eraser tends to gradually get thinner and then starts to disintegrate as you use it.
Companies that do smoke damage cleanup will do two things if the walls are not going to get ripped down. Wipe off any loose soot and the seal it with BIN.
Right. I did that for aliving in the 70's. Expert Fire damage Repair/resto. Thats exactly right. No other way. Used dirtex (a mixture of sodium carbonate , EDTA chelator, and sodium metasilicate), solution, then dry, then BIN alcohol based, sometimes 2 coats.
Yes, they do. But there it's a question of speed, manpower, customer satisfaction, the surface area involved and the fact that the insurance companies may be footing the bill. It may also be a localised soiling, in a small apartment with only a homeowner involved...different circumstances IMO.
It makes sense to remove the wall in many cases, but not everywhere. But if this tenant has been using kerosene, you might consider that the soot is in a pretty large area. It may only be visible in some areas too but it's probably the size of a whole wall, a whole room - or something of that nature. Now how much time have you got?
Considering the average situation, I'd go for dry-vacuuming with HEPA and sealing the wall/room with the shellac-based product, available in gallons or spray-cans.
the apartment is a 2 bedroom with living, dining, and bathroom. every wall and ceiling is covered with soot. dry erase is not affordable.complete removal and replacement is not affordable. what do i use to clean "loose" debris before primer and painting. also thanks for info. im kinda stuck on this one!
OK, so then you're "average"; you should have removed most of the soot using DRY means (do not soak with any liquid, but use a vac) preferably a HEPA vac you can rent for a day, with a brush. Brush every square foot.
Then seal and paint.
If you've already soaked, then seal and paint better.:yes:
I realize this message id old, but I found it with Google. Perhaps someone else will too.
We had an RV fire that left soot everywhere -- on the ceilings, on and in the cabinets, and in the carpet. Simple green removed it all. Fortunately for us, it's all paneling, stained wood, and upholstered trim. Yes, it even removed the soot from the upholstery.
Get the concentrated bottle and test diluted solutions of various strength on inconspicuous spots until you find the desired strength.
Since these are painted surfaces, after removing most of the soot, you will need to prime with one of the primers already mentioned here or with Kilz. Then repaint. In my six years of experience in rental real estate, Kilz covered just about anything -- including soot residue, tobacco smoke stains, mold and mildew stains, etc.
Bumping this up just in case there are other options. I noticed that the white crown in the den was looking kinda gray but didn't give it much thought. We pulled down the curtains to wash them and BAZINGA, there is soot all over the ceiling, trim, and walls near the back of our den. From the kerosene heater that we used two winters ago.
Other than the Magic Eraser, are there other suggestions? I'll try the Simple Green to see if that works. The areas are painted and I worry about stripping off the paint.
Ended up using Simple Green and a rag. Did a better job than the magic eraser and didn't pull apart. It still looks like crap and will need to be repainted, but I'm in no rush to do it. The whole room will have to be redone. No more karosene heaters for us!
I do not dislike magic erasers as much as many and they have their place. They are abrasive though so if you use them on a gloss surface, they will dull it. I believe they are a melamine foam abrasive in fact.
I think you are best to first vacuum all you can. Then use one of the products mentioned to clean what will come off. Finally, I would use BIN but others have had luck covering smoker homes with Zinsser Cover Stain. As mentioned, BIN is alcohol based and cover stain is mineral spirits or whatever based.
Zinsser also makes its waterbased 123 as 123+ now. The plus has a stain blocker in it. Whether it would work over soot I doubt though.
Sorry, but maybe I would use the original solvent based KILZ if stranded on a desert island and it was all their was. I don't think much of the stuff. The waterbased is worthless.
I'm not going to repaint them anytime soon. I didn't have a vacuum attachment that would reach that high so I just took a clean dry cloth and wiped the crown before attacking it with the Simple Green and eraser. Did okay and didn't seem to dull the finish, it's just really hard to get it all off without it looking like utter crap. Plus there are some areas where the caulk (??) has turned gray and it looks awful. We'll eventually repaint the entire room again but we have other more important projects going on at the moment.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
