Some Sort Of Protection Over Exterior Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 02:56 PM   #1
some sort of protection over exterior paint?
i am making a sandwich board from some leftover plywood that is going to be outside on the sidewalk, exposed to the weather, during business hours. i like the look of the woodgrain so i only want to paint the words and logos but then weatherize the entire thing. that is the best way to achieve that?
melvee is offline   Reply With Quote
Old 11-20-2011, 06:04 PM   #2
Gymschu's Avatar
Rewards Points: 1,014
There are plenty of clear coatings you can use on bare wood. Check with your local paintstore for info. Avoid anything cheap like Thompson's Water Seal. As for the painted parts, not much that really foots the bill. The exterior paint is a waterproof coating in and of itself. As long as it's a vertical surface, you should get many years out of your painted/waterproofed sign.
Old 11-21-2011, 09:51 AM   #3
Too Short? Cut it Again!
Make sure you use a clear sealer/primer before anything else. Try to get paints and clear coats with lots of UV protection. Your autobody shop might clear coat it for you cheaper than you buying finish. You can paste wax the clear coat.
Definitely stay clear of Thompson's for the sealer. It has wax in it and your paint will not stick.
Old 11-21-2011, 10:20 AM   #4
Rubbin walls since'79
Brushjockey's Avatar
Put a thinned coat of a Spar varnish on it, lightly sand- do your lettering, then finish with a coat or two more of the spar.
It is an oil finish- so be aware that it will amber- more over time.
This will change your lettering colors a bit too- blues will look greenish, etc. But it will hold up the best.
It will bring out the wood tones very nice.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-21-2011, 04:10 PM   #5
A 50/50 mix of mineral spirits and processed (not raw) lindseed oil is a tried and true old-fashioned wood sealer. It too will discolor a bit and you will have to wait it out to dry a bit.
What kind of surge protector to get for these items baby327nd Electrical 27 10-06-2011 03:35 PM
Codemakers gone wild: protection from physical damage WillK Electrical 6 06-15-2011 02:29 AM
Freeze protection in utility room? akguy HVAC 1 11-20-2009 05:30 AM
Electrical Baseboard Thermal Protection Blade_316 Electrical 5 10-22-2009 05:51 AM
Whole House Surge Protection? Ultrarunner2017 Electrical 15 02-04-2009 09:39 PM
