Solid Stain For Cedar Doors - Painting - DIY Chatroom Home Improvement Forum
Old 05-27-2008, 04:12 AM   #1
Solid Stain for cedar doors
Looking for a solid off-white stain for my cedar doors that provides the best coverage. My house is off-white stucco and I do not want the HOA required cedar doors to stand out like a sore thumb. Can someone recommend a brand and color?
merlene is offline   Reply With Quote
Old 05-27-2008, 06:58 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
If your door requires a solid stain, I can recommend the Sikkens, Benjamin Moore, and Cabot, solid stains
I don't know if Sherwin Williams has one, but if they do I'd trust it also
slickshift is offline   Reply With Quote
Old 05-28-2008, 05:55 AM   #3
Guest
Guest
Posts: n/a
I'd put Sikkens Rubbol DEK on it. This product though designed for decks will work fine on a door and give it a satin finish instead of the flat that most solid stains come in. You could also use the Rubbol Siding Finish for satin appearance if you don't mind a waterborne product.
Tags
minuet
Concrete Solid Stain vs Semi Transparent hgiljr Flooring 5 05-06-2008 05:00 PM
solid interior doors BG93245@YAHOO.COM Carpentry 4 02-24-2008 06:59 PM
Replacing hollow doors with 6 panel eehammar Remodeling 2 02-16-2008 01:27 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 07:19 PM
