Solid Color Stains - Painting - DIY Chatroom Home Improvement Forum
Old 10-12-2007, 07:07 PM   #1
Rewards Points: 528
Solid Color Stains
I want to paint some pressure treated wood with solid color stain. But is it better to prime the wood first or is it a waste of time?
rjordan392 is offline   Reply With Quote
Old 10-13-2007, 10:04 AM   #2
Guest
Guest
Posts: n/a
Most that I've seen do NOT require priming. I've only heard of priming for a solid stain in very specific situations. With Sikkens Rubbol DEK product you just use two coats of the product. It self primes on the first coat. Most should perform the same way.
Old 10-13-2007, 10:45 AM   #3
Darylh's Avatar
Darylh is offline   Reply With Quote
Old 10-13-2007, 05:55 PM   #4
Rewards Points: 528
I will probally use Benjamin Moore or Sherwin Willaims stain. I thought maybe a primer would give the top coat more longevity. I don't know if Sikkens is available in my area; I'll check. Thanks.
Old 10-14-2007, 11:36 AM   #5
Tired, Cold, and Damp
slickshift's Avatar
slickshift is offline   Reply With Quote
Old 10-14-2007, 11:40 AM   #6
Guest
Guest
Posts: n/a
Between the two I'd go Ben Moore just based on what I've been hearing lately. SW stains seem to be lacking quite a bit now days. From what I've heard locally they no longer even carry an oil stain here and almost no oil products at all.
Old 10-17-2007, 11:54 PM   #7
Paint/Faux Artisan
Da Vinci's Avatar
Sikkens is even better if you can get it. I like Cabot better than BM...
Bob
Alamo Painting Contractor
Da Vinci is offline   Reply With Quote
Old 10-18-2007, 05:54 AM   #8
Guest
Guest
Posts: n/a
Sikkens is definitely the way to go. They are making VOC compliant products now so they should be available in most areas.
Old 10-18-2007, 06:52 AM   #9
Rewards Points: 528
Thanks,
I found two stores in my area that carry the Sikkens products.
gaps between solid treads & skirt boards shotdown Flooring 9 08-02-2009 10:43 AM
Does 5" Hardwood Solid need to be glued down as well as nailed down. reibuild Flooring 2 08-03-2007 10:37 PM
torchon roof doesn't seem solid algernon Roofing/Siding 1 02-20-2007 10:01 PM
Trying to decide between granite or solid surface countertops Proulx06 Remodeling 13 02-01-2007 08:23 AM
Trimming Solid Door allen1466 Building & Construction 2 05-23-2006 09:34 PM
