Solid Color Deck Staining - Painting - DIY Chatroom Home Improvement Forum
Old 04-16-2012, 09:36 AM   #1
Solid color deck staining
Hello,
I just used Bher solid color deck stain and I'm wondering if I need to use a sealer now? Is there something I should use to finish/protect the stain? I noticed that when I move around the furniture it really leaves a drag mark on the stain. Thanks for any suggestions!
Seannyt is offline   Reply With Quote
Old 04-16-2012, 10:41 AM   #2
Too Short? Cut it Again!
Solid stains are usually not recommended for horizontal surfaces like decks. Maybe someone makes them with needed urethane or epoxy reinforcement like porch and floor paint. I certainly would not trust a BEHR product.
You probably will not gain anything adding a layer. BEHR SS is notorious for poor adhesion even on vertical surfaces. Get what mileage you can out of it and use better and more appropriate products next time.
Old 04-16-2012, 11:50 AM   #3
Rewards Points: 150
Agree fully with Sdsester. Get use and then strip, neutralize and refinish in about a year.
CaptRandy is offline   Reply With Quote
Old 04-16-2012, 06:04 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
behr stain
chrisn is online now   Reply With Quote
Old 04-16-2012, 06:12 PM   #5
Mr. Paint's Avatar
This is from the Cabot 1800 Series data sheet:
Cabot
Solid Color 100% Acrylic
Decking Stains
are extremely durable
exterior stains for use on all wood decking,
outdoor furniture and fencing, as well as
cement patios and walkways. This exceptionally
long-lasting, 100% acrylic finish is also water
repellent and fade resistant. It will resist
scuffing and dirt/scuff marks.
The next time you stain, use a quality product like Cabot 1800. It has a long history of successes.
Mr. Paint is offline   Reply With Quote
Old 04-16-2012, 06:50 PM   #6
Rewards Points: 150
Have one with Cabots Acryllic done last year by a driveway sealcoat company that I now need to strip, neutralize and seal. There are large patches that disappeared over the winter months and other places where it is pealing. Customer admitted he should have known better than use a sealcoat company to do his deck. Biggest problem is it is Indian Corn Red. Red is the hardest color to strip.
Old 04-17-2012, 06:44 AM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I've never had any issue with Sikkens Rubbol products on a deck that didn't come from application error. People around here either don't prep correctly or apply it in areas that are too close to the ground with no ventilation or no way to seal the back of the surface.
Darkling Designs
poppameth is offline   Reply With Quote
Old 04-17-2012, 08:17 AM   #8
Thanks for the replies. I know typically people don't recomend solid color stains at all but I have an older deck that was painted red then I replaced some rotten boards so I had a deck that was half red/half natural wood color. I tried stripping, pressure washing and sanding the red paint but man thats alot of work! So I had to use a solid color to cover up the two-tone deck. I'm hoping to get 2-3 years out of this solid stain (although Behr has a 5 year warrantee on the horizontal surfaces) then I'll just replace the whole deck and use a nice translucent stain.
Old 04-17-2012, 08:25 AM   #9
Any chance you could buy yourself some time flipping the deck boards over?
Old 04-17-2012, 05:46 PM   #10
chrisn's Avatar
Rewards Points: 124
Yea, good luck with that
Old 04-17-2012, 06:11 PM   #11
ltd
Rewards Points: 536
solid stain on deck . i like it ,i use to pee around with toners ,semi transparent stains for years .then i said it and put a solid stain on, and then i said to my self,and this is true i really did. i wish i would have done it years ago
ltd is offline   Reply With Quote
Old 04-19-2012, 08:07 PM   #12
Have you ever worked worth RESTORE deck stain. Have you heard anything about this product and it's ability to last for years?
ChicagoDIY is offline   Reply With Quote
Old 04-19-2012, 08:08 PM   #13
Are you a contractor in CHicago?
Old 04-20-2012, 01:49 AM   #14
I am sort of forced retired from physical aspects of trade work but doing color consulting and helping out others with project bidding from time to time. I can refer you to some folks though and help you put together a request for quotations so everybody bids on the same thing. PM if interested. I will warn you I just moved back to the City 2 years ago so am not as up on who is doing things as others might be. I think I have a handle on some good subs but not a lot of GCs yet.
Old 04-20-2012, 05:56 PM   #15
Matthewt1970's Avatar
Rewards Points: 1,098
I would not use anything but an oil stain on walking surfaces. Latex just doesn't hold up. I should get some pics of the job I did on my girlfriends deck.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Tags
behr , deck , painting , solid , stain
Acrylic Solid Stain vs Oil Semi Trans or Semi solid torxx Painting 19 10-03-2012 09:37 AM
Solid Surface vs Granite and Quartz jbeall General DIY Discussions 26 03-15-2011 04:49 PM
solid staining a deck ruthi Painting 4 06-11-2008 09:21 PM
Staining solid cherry wood Woodcutter Painting 7 12-26-2007 09:03 PM
