So Upset With Frog Tape - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 11:01 PM   #16
A Little Of Everything
Rewards Points: 1,364
Okay, now that everyone has had a little fun with this, a serious question...
Have any of you used Frog Tape? Is it okay? Good? Excellent? Worth the money?
I've seen it, and been somewhat interested, but not interested enough to buy it and try it.
DrHicks is offline   Reply With Quote
Old 06-30-2011, 11:14 PM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The OP has used it.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Evstarr (06-29-2012)
Old 06-30-2011, 11:25 PM   #18
Faron79's Avatar
Rewards Points: 260
Since our store started selling it in late 2007, it's sold very well here.
Complaints over the years..................????
I've been thinking a while, and still haven't thought of any!
The moron OP's foreclosure homes paint was probably ready to fall off anyway...as some here have said.
Packaging has always stated not to use on paint less than 2 weeks old, because FT has a "moderate" stick-level.
Faron
Faron79 is offline   Reply With Quote
Old 06-30-2011, 11:36 PM   #19
Originally Posted by Bud Cline View Post
The OP has used it.
Thank you, Captain Obvious!
The Following User Says Thank You to DrHicks For This Useful Post:
Faron79 (06-30-2011)
Old 06-30-2011, 11:37 PM   #20
Faron
Cool, that's good to know.
And yeah, the OP undoubtedly had molding that had been painted without being primed. Otherwise the paint wouldn't come off in chunks like that.
Old 06-30-2011, 11:41 PM   #21
so what happened to the OP? haven't heard much since that first post, seems like they didn't like the feedback.
Too bad, could have made for an interesting discussion on painters tape and lawsuits.
chrisBC is offline   Reply With Quote
Old 06-30-2011, 11:55 PM   #22
Faron79's Avatar
Rewards Points: 260
I still want to know the PROPER way to spell...
MODELING??!!? (as in "Interior trim use...;-))
Is it Molding....modeling....moulding?!?!?:whistlin g2:
I'm soooooo confused now...
Faron
Old 07-01-2011, 12:09 AM   #23
ltd
Rewards Points: 536
ribbit ribbit that what i think of frog tape
ltd is offline   Reply With Quote
Old 07-01-2011, 05:17 AM   #24
paper hanger and painter
chrisn's Avatar
Rewards Points: 300
moulding, is how I would spell it, now weither that is correct or not?
frog tape works well for what it was ( is) intended for, to me the regular blue painters tape works almost as well a whole lot cheaper.
chrisn is online now   Reply With Quote
Old 07-01-2011, 06:11 AM   #25
Too Short? Cut it Again!
Originally Posted by chrisBC View Post
good luck with that, next time hire a good painter, they won't have to use tape around trim.
I certainly had to have a good reason to use tape. Between baseboards and carpeting was one. Painting stripes, arches, shapes or something or another. I seldom taped between wall and trim. Just slowed me down.
Any tape will pull a poor trim job away. I have actually had good luck with Frog tape when I have used it but have no complaints against 3M either. As mentioned, I never used much.
The worst part of our foolishly litigious society is that it just jacks the prices on things up. I tried to pursue engineering and a patent on an improvement on a system for painting stairwells. I backed away because something like 78 percent of the cost of ladder system products goes directly to litigation expenses.
I am not saying there should not be avenues for legal remedies for serious things but not for obvious user fails. If the coffee is so hot it is hard to hold the cup with two layers of insulation while you unwrap the 600 calorie breakfast sandwich for the five year old? You probably should not be sipping it while laying out frog tape over modeling.
The Following User Says Thank You to user1007 For This Useful Post:
jsheridan (07-01-2011)
Old 07-01-2011, 01:11 PM   #26
Yeah I think people sometimes put too much emphasis on product and not enough on technique. You can buy the best paint in the store, but if you don't prep and put it on properly, you won't be happy. This doesn't mean the paint failed.
personally I use the blue tape when I need to tape something off. Only time i've seen tape cause an issue was when it was left on for too long, and is hard to get off.
Old 07-01-2011, 01:14 PM   #27
Yeah personally I use the blue tape when I need to tape something off. Only time i've seen tape cause an issue was when it was left on for too long, and is hard to get off.
I've had masking tape pull of paint. But in my case it was fine - even good. It pulled paint off of old oak woodwork that had been painted over, and I was going to strip and redo anyway. The wood hadn't been primed. Just paint on top of the old oak varnish.
So in a weird way, the paint pulling off the paint was a very good thing.
Old 07-01-2011, 01:17 PM   #28
yeah, i can see that happening.
sometimes it is what it is, and you just have to put in the work to make the place look nice. Good to paint trim at the same time I guess, so works out fine in the end hey.
Old 07-01-2011, 08:57 PM   #29
Tape is a crutch, learn how to paint without it. I just happen to have a great tutorial on painting without using tape. Very entertaining thread, thanks for the laugh. I wonder if she'll be back since she didn't get the shoulder she was looking to cry on.
PS, I posted before I realized there was a whole second page to the thread. I might sue if I said something embarrasing, as there should be more notice, something more prominent than a little number in the corner to notify me. There should be a pop up to notify me that I'm posting prematurely. I might get sued by OP for emotional distress caused by my callous remarks. Why don't we all sue, we can have a class action suit.
Old 07-02-2011, 04:53 AM   #30
chrisn's Avatar
Rewards Points: 300
[quote=jsheridan;678262]Tape is a crutch, learn how to paint without it. I just happen to have a great tutorial on painting without using tape. Very entertaining thread, thanks for the laugh. I wonder if she'll be back since she didn't get the shoulder she was looking to cry on.
PS, I posted before I realized there was a whole second page to the thread. I might sue if I said something embarrasing, as there should be more notice, something more prominent than a little number in the corner to notify me. There should be a pop up to notify me that I'm posting prematurely. I might get sued by OP for emotional distress caused by my callous remarks. Why don't we all sue, we can have a class action suit.[/quote]
Cuts the profits too much
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 09:17 PM
Tape Showing cougar01 Drywall & Plaster 3 03-09-2011 04:21 PM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Frozen Hot Water Pipes TravisW Plumbing 11 12-10-2009 05:26 PM
Masking and Blue tape ripping off paint LeviDIY Painting 20 10-21-2009 06:56 PM
