Snow blower paint
Inspecting my snow blower I notice a lot of rust spots in the chute and auger area. Causing throwing distance to decrease .
I can see where it would be time consuming to dismantle the auger and sandblast this area but I think this is well worth the effort ! All I need is some advise on a good paint, some thing hard to with stand stone chipping ect. If you have used any types of this paint ( I would rather spray ) If possible, But willing to mix a two part epoxy . I figure if I'm going to do this job I want to do it right once. My color now is Orange and cream ( Simplicity ) company snow blower. I might add here It's about 18 years old and Has not failed in starting with more then two pulls. of course I do regular maintenance . oh, Ya I put a new set of wheel on it, this fall, You might say I wore the wheels off !! Robut |
i wonder if it would be worth powder coating it?
Painting a snow blower
That's a term I'm not familiar with. robut |
I'd use some graphite-based paint. Brush on or spray on. Any paint on the inside of the impeller/auger area is going to get worn off anyway. Use paint that will make it more slick.
Farmers use this stuff all the time. http://lh3.googleusercontent.com/pub...f3Z1_ImSLzVQNe |
EZ Slide
Thanks for the heads up It just so happens there is a Tractor supply at the end of my street and a Family Home Farm Store in town also. It's snowing here again In Michigan, Time to Start the old blower up. Robut |
But look at it this way: It's not going to destroy anything, and if you really don't like it, you can strip away the remainder of it (in the spring), then prime & paint with something else. |
| All times are GMT -4. The time now is 08:13 PM. |
