Old 03-08-2011, 07:13 PM   #1
Smoothing Painted Wood
Hi All,
I have a half wall separating the kitchen from the den and on top of this wall is a small area for ornaments. It's been painted several times over the years and the surface is no longer smooth.
I've tried sanding but sanding doesn't seem to work on painted surfaces.
How do I handle this?
Thanks in advance,
Bob
Bob Guercio is offline   Reply With Quote
Old 03-08-2011, 07:54 PM   #2
Try an orbital sander. Find a grit that will take the edges, brushmarks,etc. off and go to a finer grit to finish. Since this is in your house use a vaccum attachment to minimize the dust.
kboyz is offline   Reply With Quote
The Following User Says Thank You to kboyz For This Useful Post:
Bob Guercio (03-08-2011)
Old 03-10-2011, 09:41 AM   #3
The makers of Bondo also make a finer paste to use to fill in and skim over traditional bondo as a finish coat. They now make a general purpose bondo for home projects. This might help fill some of the low spots after Kboyz treatment, don't try to sand out low spots, fill them. It's available at your local supplier of Behr paint.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 11:56 PM
Anyone PAINTED wood trim? hellothere123 Painting 7 04-09-2009 07:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
