Smoothing A Door With Peeling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 01-30-2007, 06:23 PM   #1
Smoothing a door with peeling paint
I'm working with a hollow wood door (about 30 years old). It was painted, then wallpapered.
I removed the wallpaper from the back of the door, scraped all the glue and loose old paint off, washed it, and gave it a coat of oil based primer. I'd like to use a semi-gloss so I definatly need somthing to smooth it out with before giving it a final prime and topcoat. My question is what do I use? Seems to me like spackle would just crack given the nature of wood and it being a door. Wood filler seems a little too solid to work into such a shallow wide groove.
Tmb9862 is offline   Reply With Quote
Old 01-30-2007, 08:54 PM   #2
Pro Painter
For future reference the door should have been either replaced or stripped.
Bondo might work to smooth it with, but in this circumstance it's a maddening process. No matter what you use or how much you feather it, more than likely it's going to show through the semi-gloss.
joewho is offline   Reply With Quote
Old 01-31-2007, 12:14 AM   #3
Thanks.
I completly forgot bondo can be used on wood. I think I'll give it a shot and see how it goes.
Stripping it is another great suggestion though if the bondo doesn't work out well. It wouldn't take too long to bring it down to the garage, hit it with that Silent Paint Remover contraption and repaint it.
Old 01-31-2007, 12:24 PM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Don't do the bondo. If you do then stripping would be next to impossible.
You can get hollow core wood doors for like $15 or $20. Just replace it, it may even be cheaper than bondo!
Brik is offline   Reply With Quote
Old 01-31-2007, 03:38 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
I use joint compound for smoothing out doors
Just like a wall
slickshift is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
how to remove peeling semi-gloss paint amydiy Painting 5 04-09-2007 10:06 PM
Peeling paint Lisalovespainting Painting 7 02-17-2007 08:52 AM
Peeling Paint lawlor Painting 2 12-30-2006 03:28 PM
Latex paint peeling...HELP coorsabee Painting 4 09-11-2006 10:16 PM
