Smooth Painted Walls - Painting - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 03:54 PM   #1
smooth painted walls
I want to paint my familyn room wall i want a very smooth finish what is the best roller cover to purchase.
beckner is offline   Reply With Quote
Old 08-15-2011, 05:59 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
What paint are you using? Smooth is more operator than roller. Many of us can make a smoother finish with a 1/2 " than a DIY can with a 3/8.
Use good materials and quality tools . That is huge.
Brushjockey is offline   Reply With Quote
Old 08-15-2011, 06:06 PM   #3
Gymschu's Avatar
Rewards Points: 822
The smoothest walls I ever achieved were with a mohair roller cover using OIL-based Satin from Sherwin-Williams. In today's world with almost all latex paints, a perfectly smooth wall takes some work. If it's new drywall, a great primer is a must, then a thorough sanding, followed by a cleanup of the walls.........then apply your first coat, allow to dry for a day or so, then another light sanding, clean, and apply final coat. To attain perfection, well, it's tough.......no matter what the roller cover, you still get some shedding of the fabric onto the painted wall..........also, there's "buggers" in the paint. Good luck.
Old 08-15-2011, 07:42 PM   #4
The smoothest walls I ever did (years ago) was with BM Dulnamel oil eggshell, all coats rolled on and tipped ( backbrushed) floor to ceiling- paint thinned to perfection.
Waterbornes just don't give you the time to do that.
Might be able to do it with spray if you really knew what you were doing.
Old 08-15-2011, 08:29 PM   #5
Gymschu's Avatar
Rewards Points: 822
As for roller covers, I either buy the best Wooster roller cover I can find with 1/2 inch nap or Purdy's Golden Eagles.
Painted wood walls - couldn't take the depressing darkness! mrs1885 Project Showcase 6 01-09-2011 10:03 AM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
removing knockdown texture from painted interior walls skdahl General DIY Discussions 6 04-11-2008 11:02 AM
snading dust off new painted new sheetrocked walls purplezee Building & Construction 3 02-25-2007 04:59 PM
