Smooth Paint Surface - Painting - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 09:19 PM   #1
Stairguy
Millertyme's Avatar
Rewards Points: 508
Smooth paint surface
I was at a job site today after the painters had finished their work. This was by far the best work I have ever seen. There was lots of woodwork in the house, wainscoting, stacked crowns, and lots of other painted woodwork. I was told they sprayed it all. This stuff was so smooth that it looked like plastic. There was no orange peel, dust or other debris in the paint, or any other blemishes in their work. I have used hvlp guns in the past, and think I can do pretty good for not being my profession. I'm sure they use an airless sprayer though. Would that make that much difference? Or is it the type of paint or additives they are using. I really wish I saw them at the job site so I could pick their brains for a bit.
Millertyme is offline   Reply With Quote
Old 01-05-2012, 09:59 PM   #2
Gymschu's Avatar
Rewards Points: 496
Millertyme, as any painter will tell you, "It's all in the prep." I'm sure that woodwork was sanded, vacuumed, primed, sanded again, vacuumed, sanded again.......anyway, you get the point. Most professional painters I know can make any paintjob as "smooth as a baby's behind" IF, and that's a big IF, they are allowed the time by the contractor or the homeowner to do it up right. And, to be honest, using quality paint sure helps too.
The Following User Says Thank You to Gymschu For This Useful Post:
ltd (01-05-2012)
Old 01-05-2012, 10:38 PM   #3
we used to do those kind of jobs everytime. like Gymschu said it's all in the prep. we would spend all day sanding and vacuuming after caulking and puttying and then it would take less than 2 hours to spray the whole house. next day same scenario. we did 2 coats of primer and one coat of finish. like Gymschu said you need quality paint. we used benjamin moore impervo oil and all the trim felt like it was plastic coated, smoother than a babies bottom. the BM impervo oil comes out pretty good using a brush also.
The Following User Says Thank You to DannyT For This Useful Post:
Gymschu (01-06-2012)
Old 01-06-2012, 04:49 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
really?
chrisn is online now   Reply With Quote
Old 01-06-2012, 05:25 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
I have done projects in the past where I have primed with quality primers and used good paint but still haven't achieved results quite like this. Maybe it's the gun I use. I use a porter cable hvlp sprayer.
Old 01-06-2012, 05:40 PM   #6
yes 2 coats of primer. the guy i worked for did it that way. the primer sanded really nice and smooth, was sherwin williams and was half the cost of the BM impervo. i questioned it once and then after seeing how it turned out i was amazed. he used an airless. one contractor that was in a home show house we trimmed and painted stop by another job we were working on and asked how we got it so smooth, i told him " a lot of prep work".
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Spray paint accident help the_M_man Painting 19 07-22-2011 03:14 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
