Smooth finish on wood doors
I'm interested in painting our interior doors a dark grey or charcoal but I'm curious as to how I can achieve a super smooth finish. At the moment we have the typical white, wood grain interior doors. I'm not sure if they could be sanded but even so, with all the panels and grooves it would probably be a massive pain.
Would a couple good coats of primer before the paint layer give it that "candy coating"? Here's what the doors look like now: http://i45.tinypic.com/34pibcw.jpg http://i45.tinypic.com/6oooxk.jpg |
Multiple coats of primer serve no purpose when it comes to the final finish.
You are not going to be able to sand that texture off so get used to it. You can apply a brush stroke free finish though. I would use a really nice 2.5" angled sash brush. I would get quality paint from a paint store, not a box store. Assuming you buy a waterbased semi-gloss or something I would buy a bottle Floetrol also. Mix the Floetrol into your paint per directions. Have at the doors. Start by painting the inset panels. Then move on to the major horizontal and vertical components of the doors. |
If it were me I would be looking at buying new doors if I wanted a smooth door finish. Sanding won't work well, filling would be even harder.
Mark |
Yes that Titan sprayer will work fine my only suggestion is if you have never sprayed before get some big pieces of cardboard, old plywood, or drywall and practice,a lot before you start. Also there are some good videos on youtube for spraying doors you might want to check out. Good luck.
The sprayer will not fill in the wood grain look that is for certain.
sorry didn't mean to imply they would. your right.
Those are hollow core MDF doors, MDF means medium dencity fiberboard. Sand them to much and you get what looks like ground up newspaper.
Except for the spelling, Joe is correct and Jacko is also:thumbsup:
Is spell check not available in Va? |
| All times are GMT -4. The time now is 08:46 PM. |
