Smoke On Walls In Kitchen - Painting - DIY Chatroom Home Improvement Forum
Old 07-10-2007, 09:57 AM   #1
Smoke on walls in kitchen
Have a rental property that i need to paint. In the kitchen on some of the walls and a small part of the ceiling there is what appears to be smoke on the already painted semi gloss paint. The tenants tried to wipe it down with out much success. Do I need to do anything special before painting the walls?? Thanks
diylady is offline   Reply With Quote
Old 07-10-2007, 12:32 PM   #2
Workaholic's Avatar
Rewards Points: 268
I would sand the walls to scuff them, then i would wipe all dust off wall, and then i would apply a primer, such as bin or kilz or gripper, or gardz, then i would topcoat. I would also get your primer of choice tinted to the color of the top coat.
Sean
Workaholic is offline   Reply With Quote
Old 07-11-2007, 09:10 PM   #3
Pro Painter
More than likely, it's grease and or smoke. Even if you prime with a solvent base, it needs to be cleaned with something like tsp. If it's an enclosed or galley kitchen, with a little filter over the stove that blows back into the apartment, there's definately a film of grease. Sanding will probably gum up the paper.
Could be wrong, if it's only smoke, it should also be washed. If the tenants used soap, it won't look any better but will be ready to sand and prime. Grease will gum up the sand paper.
joewho is offline   Reply With Quote
Old 07-12-2007, 10:08 PM   #4
Pro Painter
And, believe it or not, a thick coat of smoke or grease will produce odor right through the paint, if not cleaned properly.
Old 07-13-2007, 04:56 PM   #5
Workaholic's Avatar
Rewards Points: 268
Joe is absolutly correct. It was my over sight not to mention to clean the walls before sanding, which is what i should of said.
Sean
Old 07-13-2007, 06:47 PM   #6
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by diylady View Post
...there is what appears to be smoke on the already painted semi gloss paint. The tenants tried to wipe it down with out much success. Do I need to do anything special before painting the walls?? Thanks
It depends on what it is as th the exact steps
But it should be cleaned (as well as possible), and sealed
The sealer would depend on what it is and how bad
It is more than likely going to need (at least) an oil-based primer/sealer
It is possible it may need the Big Guns, a shellac-based sealer
Frankly, as a rental, I would go straight for the Big Guns and use Zinssers BIN over the area
As rental, the stain could really be anything
Best to BIN it and no worries
slickshift is offline   Reply With Quote
Old 07-13-2007, 09:45 PM   #7
Paint/Faux Artisan
Da Vinci's Avatar
I agree. Don't use oil based, because grease and nicotine can leech through the oil product. Zinssers White pigmented Shellac dries fast and hard and will lock in odors and stains, provide you clean with TSP beforehand.
Bay Area Painting Contractor
Da Vinci is offline   Reply With Quote
Old 07-14-2007, 10:09 AM   #8
Thanks all for your responses. I got a chance to take a better look at it and it is definitely soot i think from candles,they were big candle people. Came off on my fingers and wasn't greasy.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
tin walls and kitchen cabinets MKemnitzer General DIY Discussions 6 01-05-2007 03:47 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
