-   -   Smoke on walls in kitchen (http://www.diychatroom.com/f4/smoke-walls-kitchen-9787/)
diylady 07-10-2007 09:57 AM
Have a rental property that i need to paint. In the kitchen on some of the walls and a small part of the ceiling there is what appears to be smoke on the already painted semi gloss paint. The tenants tried to wipe it down with out much success. Do I need to do anything special before painting the walls?? Thanks
Workaholic 07-10-2007 12:32 PM
I would sand the walls to scuff them, then i would wipe all dust off wall, and then i would apply a primer, such as bin or kilz or gripper, or gardz, then i would topcoat. I would also get your primer of choice tinted to the color of the top coat.
joewho 07-11-2007 09:10 PM
More than likely, it's grease and or smoke. Even if you prime with a solvent base, it needs to be cleaned with something like tsp. If it's an enclosed or galley kitchen, with a little filter over the stove that blows back into the apartment, there's definately a film of grease. Sanding will probably gum up the paper.
Could be wrong, if it's only smoke, it should also be washed. If the tenants used soap, it won't look any better but will be ready to sand and prime. Grease will gum up the sand paper.
joewho 07-12-2007 10:08 PM
And, believe it or not, a thick coat of smoke or grease will produce odor right through the paint, if not cleaned properly.
Workaholic 07-13-2007 04:56 PM
Joe is absolutly correct. It was my over sight not to mention to clean the walls before sanding, which is what i should of said.
slickshift 07-13-2007 06:47 PM
Originally Posted by diylady (Post 52368)
...there is what appears to be smoke on the already painted semi gloss paint. The tenants tried to wipe it down with out much success. Do I need to do anything special before painting the walls?? Thanks
It depends on what it is as th the exact steps
But it should be cleaned (as well as possible), and sealed
The sealer would depend on what it is and how bad
It is more than likely going to need (at least) an oil-based primer/sealer
It is possible it may need the Big Guns, a shellac-based sealer
Frankly, as a rental, I would go straight for the Big Guns and use Zinssers BIN over the area
As rental, the stain could really be anything
Best to BIN it and no worries
Da Vinci 07-13-2007 09:45 PM
I agree. Don't use oil based, because grease and nicotine can leech through the oil product. Zinssers White pigmented Shellac dries fast and hard and will lock in odors and stains, provide you clean with TSP beforehand.
Bay Area Painting Contractor
diylady 07-14-2007 10:09 AM
Thanks all for your responses. I got a chance to take a better look at it and it is definitely soot i think from candles,they were big candle people. Came off on my fingers and wasn't greasy.
