Slippery Painted Outdoor Steps - Painting - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 01:32 PM   #1
Question
slippery painted outdoor steps
Can I use a sandy grit either on top of my wet paint or add to the paint to make my steps less slippery.?
ican2 is offline   Reply With Quote
Old 02-17-2013, 01:43 PM   #2
cdaniels's Avatar
There are additives that will help.Check your local paint store.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 02-17-2013, 01:57 PM   #3
I've never used it, but I've heard that Shark Grit, at Sherwin Williams, is the best.
The Following User Says Thank You to jsheridan For This Useful Post:
ltd (02-17-2013)
Old 02-18-2013, 10:25 AM   #4
Rewards Points: 394
Skid Tex, Safe Step are other additives which work well.
Will22 is offline   Reply With Quote
Old 02-18-2013, 11:22 AM   #5
Rewards Points: 384
Hiya ican,
Go back through this forum's archives to this post:
Painting a Porch - 8/17/2012 - OP: beanie34...
Start with post #5 - then see SDSester's comments and photos...
That was a really good discussion, regarding your same topic, with better, safer and longer lasting options to providing a skid-resistant finish. Good luck.
ric knows paint is offline   Reply With Quote
Old 02-18-2013, 11:50 AM   #6
Rewards Points: 2,038
corner tape
wrong spot to post.
Startingover is online now   Reply With Quote
Old 02-18-2013, 04:21 PM   #7
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Shark Grit from Sherwin Williams is a great product, as an anti slip additive. Its applied with your final coat and can't be seen after aplication, but is there and does work. We use it all of the time when refinishing a surface that may be slippery, especially masonry surfaces.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
Gymschu (02-18-2013)
Tags
slippery outdoor steps
Seeking help and advice with hideous painted brick fireplace sparkler22 Painting 12 12-03-2011 07:46 PM
All surfaces painted with a brush different from surfaces painted with a roller. praktikal Painting 16 04-06-2010 09:45 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 12:50 PM
Fresh painted white baseboards turning yellow laurenkemp7 Painting 2 09-01-2009 09:26 AM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 12:50 PM
